Does it shoot bowling balls?
I don’t care if it’s legal or not, I want one!
You should read the rules before you ask rules questions.
It clearly says that you can’t use COTS parts that are worth more than 400 dollars, such as a forklift or engine.
Is this just a random picture, or did you actually meet (and, I hope, try out) a giant pitching machine?
I really want to see a video of that beast running…
As long as you get the guy from the junk yard to write “V8 Seat motor” on the receipt, I believe it’s legal
I believe it pitches a 2x4
I can’t tell from the angle but I think this may violate the weight limit. ::rtm::
I use to be an engineer like you. Until I took a bowling ball to the knee.
that really depends on what your trying to do, oblitarate the competition (and the playing field) or get a good laugh
Never saw it, searched Google for pitching machine. This came up, thought it was fitting. It almost looks like it shoots 8’ 2x4’s or 4x4’s with the plexiglass frame behind it.
EDIT: You could possibly build this with items less than 400 bucks. Just look at 24 hrs of lemons racing.
This is illegal??
Back to the drawing board.
Just wanted to say, I cracked up so much when I saw that picture…sadly I think it violates some important rules, such as each part being no more than $400, the robot can’t weigh more than 120 lbs, you aren’t allowed to destroy the arena, and you can’t destroy the “competition”, but otherwise, I say its perfectly legal!
Guys,
Did you not read…
The only legal source of electrical energy for the Robot during the competition is one MK ES17-12 12VDC non-spillable lead acid battery, or one EnerSys NP 18-12 battery, as provided in the 2012 KOP. This is the only battery allowed on the Robot.
I think it is fully established that this is a “joke” thread with the first picture.
As is my reply…:yikes:
At the same time… That can be the only source of electrical energy. The rest is just done by the v8.
Our team began prototyping last year with a matter-antimatter engine until we realized we had gone way over the $3500 allowed on a robot. I’m sure it would have won us the Engineering Inspiration award if we’d been allowed to use it though.
EDIT: ^^ quote fail.
The V8 produces electricity to fire the spark plugs(alternator).
However, you could a V8 diesel (no spark, no alternator necessary).
problem solved
(now for weight… freshmen with holesaw)
I guess at the same time, you would have to switch the starter motor out with something from the Kit of Parts. Either that or stand on the field before the match starts with a hand crank
