Vacuum Pump
Ok we have a vacuum pump and motor assembly. Its a off the shelf assembly. Is it leagle to run the stock motor? Or do we have to use a KOP motor, wich is way to much power. The assembly is a hargraves BTC-IIS series pump.
Here is the link to the Data sheet.
http://www.hargravesfluidics.com/pdf…Data_Sheet.pdf
Thanks
Hayden Taylor
Team #2767
The only motors you can use that did not come in the KOP are the exceptions listed in <R52-B>-<R52-D>.
Basically you will have to use a KOP motor or one of your allowable additional CIMs to power the pump.
Also, your data sheet link is broken.
