Variable Driven 8WD CAD
This is a variable driven drivetrain, with several different variables like, frame width and length, extrusion dimensions, center drop, and belt center to center distance. I’m not sure how the file paths on the equations will work out, but PM me if you’re interested in actually getting it to work if it doesn’t. The text file is called “Test Drive Train Variables”. This is my first time releasing a CAD project, so pardon my mistakes.
There should be all the files and some renders in the GrabCAD Partner Space, please drop some advice if you see something that you would change!
https://workbench.grabcad.com/workbench/projects/gccfPD_Joy_PgI3RbT1jSo-2PODQ0D3NkWLEIiDcw68rQw#/space/gcGvJ8EyKNZK_8SQ9gzjXVEAJMiOmH3QGb2F5zEX5rTxh8
