I’m looking for a way to save a text box to a MSWord .doc using VB6. I’ve tried some things but they aren’t working. If I can get it to work I also need to set margins and font size and font name.
I’d Appricate any help I can get with this.
There are two methods to do this:
Wow. I would have used VBA or something. Nice!
VBA would only work if PaPPy was writing a VBA program in the first place. If he wants to save a .doc file from VB, he’ll have to do it externally.
First, add a reference to the “Microsoft Word 10.0 Object Library” from the Project->References menu.
This subgroutine will create a new word document and write a block of text to it:
Sub WriteWordDoc(content As String, _
filename As String, _
Optional font As String = "Verdana", _
Optional fontsize As Integer = 10)
Dim app As Word.Application
Dim doc As Word.Document
'get an instance of the MS Word application
Set app = CreateObject("Word.Application")
'create a new document
Set doc = app.Documents.Add
'initialize the document and write the content
With doc.content
.font.Name = font
.font.Size = fontsize
.Text = content
End With
'save the document and close Word
doc.SaveAs filename
doc.Close
app.Quit
Set doc = Nothing
Set app = Nothing
End Sub
The app.Quit line is important, otherwise it will keep Word open in the background. If you add the line “app.Visible = true” and remove “app.Quit” then you will see Word open with your new document.
Will a similar setup work with other versions of office? (and won’t the ‘doc.Close’ make ‘app.Visible = true’ a little useless? Slight bug.)
I would suggest you try using C# or VB.NET if you’re just getting started with VB. The VS 6.0 tools won’t be supported forever and you can do everything (and a lot more) with the .NET SDK.
Here is a sample class that has a method to save the information to a Word document. It only has two properties, Name and Bio. The Name will be written in 12pt Bold and the Bio in 10pt normal font. There is an overload that defaults to hiding and closing Word.
public class Person
private string name;
private string bio;
public Person()
name = string.Empty;
bio = string.Empty;
public Person(string n, string b)
name = n;
bio = b;
public string Name
get { return this.name; }
set { this.name = value; }
public string Bio
get { return this.bio; }
set { this.bio = value; }
//overload of the ToWord method that does not display Word
public void ToWord(string filename)
this.ToWord(filename, false);
//ToWord method writes the bio information to a new Word document.
//the Show argument specifies whether we keep Word open.
public void ToWord(string filename, bool show)
//pointer to Word application
Word.Application app = new Word.Application();
//create a new document
object opt = Missing.Value;
Word.Document doc = app.Documents.Add(ref opt, ref opt, ref opt, ref opt);
Word.Paragraph p;
//add a new paragraph and write the person's name
doc.Content.InsertParagraphAfter();
p = doc.Content.Paragraphs.Item(1);
p.Range.Font.Name = "Verdana";
p.Range.Font.Size = 12;
p.Range.Font.Bold = 1;
p.Range.Text = this.name;
//add a new paragraph and write out the bio
p = doc.Content.Paragraphs.Item(2);
p.Range.Font.Size = 10;
p.Range.Font.Bold = 0;
p.Range.Text = this.bio;
//save the document
object file = filename;
doc.SaveAs(ref file, ref opt, ref opt, ref opt, ref opt,
ref opt, ref opt, ref opt, ref opt, ref opt, ref opt,
ref opt, ref opt, ref opt, ref opt, ref opt);
if (!show)
doc.Close(ref opt, ref opt, ref opt);
app.Quit(ref opt, ref opt, ref opt);
else
app.Visible = true;
