Veteran Teams have No Advantage
Two things:
  1. Off topic a bit, but every time that a thread like this pops up, we are justifying the current failure that is the match sheduling system. By saying that it levels the playing field, people from FIRST think more and more that this is acceptable. I’m going to be blunt and say it: I ama against the current algorithm (spelling?) and expect first to come up with something better that will pair us with and against a bigger variety of teams
  2. There are verteran powerhouses (someone mentioned 25 and 254) but there are also rookie powerhouses. Maybe they dont win a regional every year, but every year you will see rookies that mow down veterans. 1503 won 3 regionals last year, with 1114 (both relatively new teams). It’s a fact that rookies and veterans are both FIRST teams, and given similar knowledge, they will both perform well.
Let’s let FIRST know that we want to play against everyone, rookies and vets.
It’s not veteran status. It’s not rookies status. It’s infrastructure. The teams that are well organized, well directed and are set up to ensure longevity are the ones that do well.
In order to be successful, you have to learn from experience. Rookies that have experienced mentors and enthusiastic members will do well (see 1902 for a prime example).
On the flip side, veteran teams that have no continuity from year to year are going to do poorly, or have mixed results. Not having any information on past robots can be very detrimental, as the team has to re-learn all of it’s previous mistakes. Team handbooks, dedicated sponsors and supportive communities are the marks of successful teams.
One advantage that vetern teams DO have is their lower number and their team history. I have been at many a regional where a Big Name team didn’t have the strongest robot of the litter but they were picked based on reasons other than that particular years robot performance. Sometimes it is the experience under pressure, sometimes it is the way they sell themselves, it could have even been that it was an incredibly robust machine and went out for every single match. Either way you don’t have to have the #1 seed robot to be on the winning team, you may even have the worst robot at the regional (Based on the qualifying match scores) especially this year when you see some of these matches go so lopsided when the right robots are out there together against and unevenly matched oponent.
This argument only supports the reason for a new algorithm. The less teams one is exposed to, the less quality information he is likely to have, the more likely he is to revert to picking a low-numbered team. Hence, we should revert to a random algorithm, that will let each team compete with and against more teams.
-Guy
EDIT: Results from the inference I ran on last year’s regionals results are coming tomorrow. I promise :stuck_out_tongue:
Our scouting team took data on the number of tetras/balls actually scored by robots at the regionals we were attending. This may be more reflective of how teams are actually scoring. The only data I have access to at the moment is the data for the 2005 Chesapeake Bay Regional. So, out of 55 teams at the regional, 25 (45%) were numbered above 1000 (arbitrary number) with 9 (16.3%) being rookies. Looking at just the top 8 (scorers, not seeds), 2 (25%) were numbered over 1000, 1 (12.5%) was a rookie team. If I pick an arbitrary number again, like 2 tetras, 36% of teams that scored 2+ tetras were numbered over 1000 and 18% were rookies.
So I’m not sure if this data is in any way meaningful, but it may be more meaningful if someone keeps data on scoring, or something along those lines, to compare that to team number (in a more meaningful way than this) or to compare scoring to seed this year and last year (for example what % of the top 8 seeds were also in the top 8 scoring this years as compared to last year) to see if this algorithm is having an effect on where the highest scoring teams seed. (I can’t do that here because I don’t know the seeds for 2005 Chesapeake)
Or it might all be meaningless. But match results definitely do not equal scoring ability (the highest scoring robot in the Curie division at 2005 Championships was seeded 11th). Although, scoring ability definitely does not equal robot quality.
Because the controversial scheduling system is in place, all this shows that the desired effect of the system was achieved. Every match a low number team won, a low number team lost.
This data is meaningless.
Also, I am in no way supporting the existing scheduling algorithm.
I would not base anything off of this year. This year is just starting and the “veteran” teams have many competitions to go to. I would personally base any information off of the championships, for any year. If you are a good team then you will strut your stuff in the finals. All teams who have a good robot will have a good team. Not all veteran teams have good teamwork, but they do have the experience of doing this kind of thing over and over. I really want the rookie teams to shine this year which is what keeps the FIRST spirit strong.
At BAE, 58 scored the most game pieces (20) on Friday. 1276 scored the next most (18). Then came 1307 (16) and 1073 (13). Then there was 175 (12).
All of these teams are at least at the end of a high school cycle. 58 was a rookie just before '98. 1276 and 1307 were rookies in 2004. 1073 has at least five years experience (maybe 6), Buzz was a rookie in '96.
I don’t see a whole lot of correlation here, other than all of these teams have at least 4 years under their belt. BAE is pretty heavy with old teams, so this data may be weighted. I would say veteran teams should have an advantage, put after your third year, you’ve had the opportunity to learn as much as you need to be competative (with experienced mentors, this knowledge should come even quicker).
Outstanding work.
Hypothetically, say two very low numbered teams (0.1 and 0.2) are in the same regional. They are also the best teams at the regional. They are very close to each other in competition, but far and away from any other team there. According to the algorithm, it would be safe to say that 0.1 and 0.2 play each other quite a bit, and it would not be out of the question that they both end up with a .500 record.
Given the current algorithm, that would mean the two best teams aren’t even close to being captains.
Not fair by a long shot. (However, being a 4-digit team ourselves, we’re not complaining)
Hopefully this year the scouts will do a good job and evaluate each team by their capabilities and potential rather than their win-loss record, and the cream will rise to the top come Elimination time.
You raise a good point about the match scheduling system at the first weekend regionals ensuring that every match a low numbered team won, a low numbered team also lost, however that doesn’t make the data meaningless. It may mean precisely what you suggest when you say “the desired effect of the system was achieved”… which is a meaningful conclusion.
If we run a similar analysis after the second weekend regionals and see a correlation between team number and qualifying success it will demonstrate that at first weekend regionals there was an artificial barrier to the win/loss record of some teams, and will have some more solid evidence to back up the “common sense” idea that veteran teams do have an advantage – in general – over newer teams. Something that – frankly – I’m okay with. There should be some benefit to years of hard work… not an insurmountable or overwhelming benefit, but some benefit at least.
Thanks to everyone who has joined in with ideas, thoughts and suggestions – particularly the statistics and observations from previous years. I’m looking forward to seeing what this weekend brings as it looks like FIRST is moving quickly to resolve this particular issue.
Jason
As a mentor of 1902 I agree. My previous team 1083 the school decided not to continue the team. A team mom on 1083 from another school decided to run it from their home without official shool sponsership and so at last minute started 1902.
But we pulled in experienced students, college mentors, adult mentors. George has 10 years experience, I have 5.
We are lucky to have deep infrastructure:
Strong hardware and partnered with another team to fill in our weaknesses
Strong software that has developed successful auto modes
Strong driver strategy and strong drive team
Strong non-engineers that raise money and awareness
It takes all that and more to make a succesfull team.
But we are still growing and learning what infrastructure it takes to run a team and be succesful. We are still making rookie mistakes but are learning and adjusting to those mistakes.
Big one last year when the hardware guys gave us a day to to auto mode and it put us ahead of others. This year they worked hard and delivered the bot over a week ahead so we had lots of driver practice, spent 60 hours on details of software and auto mode and worked out hardware problems.
Final thing is the team is fun, that stage being set by our team leader Wendy, we work together well.
