Hey everyone, I’m a little puzzled…
I’m having a slight issue with programming my Vex r/c. I can’t get the motors to run under r/c control. I don’t get it. Everything is plugged in, crystals match, motors plugged into the right port, etc. I can get motor ports 2 and 3 to run under the default code. I also can get it to run under online code. Making the motors run with a pwm value also works. I just can’t figure out why the r/c control isn’t working.
If you are using easy C 2 for Vex, you probably forgot to put a while==1 loop in the operator control program. This needs to surround the entire program to have it run continuously.
No, I want them to be independent of each other so that it can have the 4 speeds. I don’t have the Advanced Gear kit yet, so I’m just going to have two motors with move them with a little lever or something.
You don’t really need it at all, but it still shows the teams mechanically abilities. It could get the think award if you explain it to the judges well enough. Also, you would have to state the reason of why you did it though.
