Hey guys,
I can’t find these screws dimensions, does anyone have it ?
VEXpro Ball Shifter Hardware Kit - VEX Robotics
Thanks guys
Team 5553 from France
Dang that’s a shame they do not have the components listed, they should. Eyeball sas they should be 8-32s and 10-24 threads. But I could be wrong, not sure on length.
The ball shifter assembly instructions will have the part call outs (under docs and downloads) this will take a little bit of sifting through the .pdf
https://www.vexrobotics.com/3cimballshifter.html#attr-vex_docs_downloads
Is this for the 2 or 3 cim version? 3rd stage?
ok i’ll go and see thanks
well actually i’m trying to find the right screws dimensions for ball shifter shafts : Ball Shifter Short Output Shaft v2 - VEX Robotics
yeah but can you find it there ? I personally don’t
If you are talking the output shaft that takes a 1/4-20 .500" long.
Ok thank you very much
