VH-109/VH-113 Firmware v1.2.5 [CRITICAL UPDATE]
Hey everyone,
Today we’ve released firmware v1.2.5. We recommend that everyone update their radios to this version ASAP to avoid potential issues in the future.
Why is this a critical update?
We’ve received some units from the field where the flash memory that stores some of the radio’s calibration is corrupted. This causes the radio to go into a bootloop.
Here’s an example:
memory-corruption-behavior
The 1.2.5 release has a mitigation to address this potential corruption. We recommend that all VH-109s and VH-113 be updated to this ASAP.
What to do if your radio is affected by this?
If this happens to your radio, we do have a way of recovering the radio remotely. Contact WCP Support, and they’ll coordinate the remote support with Vivid-Hosting.
Here’s an example of how remote recovery works:
VH-109 Remote Support (youtube.com)
Thanks!
Will the radios included in the KOP have this firmware?
RIP anyone a) not on Windows and/or b) Can’t install Anydesk due to school/IT restrictions. (Nevermind school firewall/filter issues)
Is there some reason we can’t recover this ourselves?
There’s a macOS and Linux client. I’ll be publishing those today.
I’ve remotely supported teams who couldn’t figure out how to un-AP their radios in the past when their school firewalls blocked the connection. We just had them hotspot off their phone.
Unfortunately the only way to recover this requires restricted access to the device as the partition we’re accessing was explicitly called out as a protected region during the regulatory approvals.
Unfortunately not. However, we have so far only observed this behavior on earlier firmware releases from the factory at v1.0.
The KoP and FC radios were shipped with v1.1.2 installed.
Just my opinion, but something of this nature should be in a FRC blog post or some other official communication once everyone is happy with the procedure…
There are potentially a LOT of teams impacted. While CD has good reach, it’s not quite far enough to be a proper backstop solution.
We’ve already communicated this to our counterparts at HQ. We’re sure something’s going to go out.
I don’t know how far in advance KoP things are done or if this would be feasible, but maybe putting some kind of scary “UPDATE REQUIRED BEFORE USE” sticker on the radio box that you have to cut through to open would be a good way to prevent teams from missing it?
Unfortunately, pretty far in advance…
Which is why there’s an Inspection Checklist item for firmware versions.
Won’t snag all the teams in their shops, but…
Are there any plans to add text specifying the installed firmware version to the configuration webpage? imo this was a huge oversight and made troubleshooting and upgrading firmware a pain. Other debugging info would be great too.
Open http://192.168.69.1/status (write “status” instead “configuration” in the URL of the Configuration Page) for detailed information about your radio.
It’s there now at the bottom of the page. For builds before 1.2.3, /status does give that info as said above.
Thank you both! I couldn’t find (and still can’t) that anywhere in the docs. Am I just missing a page or is this undocumented?
https://frc-radio.vivid-hosting.net/miscellaneous/firmware-changelog#vh-109_1.2.3-10242024
It was in the changelog (The change to the main page). The status json report isn’t documented from the looks of things.
After upgrading our radio to v1.2.5 it will no longer connect to our Rio. The radio was one of the ones given out at worlds this year, running 1.0.0 prior to upgrade. It was working prior to applying the firmware update. Any suggestions?
I’ve confirmed it’s not an issue with the ethernet cable or the rio ethernet port.
After the firmware upgrade, you will need to program the radio for your team number again.
https://frc-radio.vivid-hosting.net/getting-started/usage/programming-your-radio
After the firmware upgrade I set the team number, SSID and WPA keys. I can connect to the wifi network and access other devices, such as photonvision on our coprocessors connected to the switch. The rio cannot be accessed using the static 10. IP address or the mDNS name.
Sounds like you have a static IP address set on the roboRIO. Are you able to connect to it over USB and confirm what IP addresses is set?
Yes, I’ve confirmed that the IP is set correctly when connected via USB. This is the 10.TE.AM.2 IP I’m referring to. If we swap out the vivid hosting radio with one of the old FRC radios we’re able to connect to the Rio fine. I’m going to try applying the latest Rio firmware update from NI game tools this weekend to see if that has any effect.
But if you open the roboRio web interface (by navigating to that IP when USB tethered to the robot), is it a STATIC IP, or DYNAMIC/DHCP setting?
Additional screenshots would also help people troubleshooting with you
