I am a mentor for team 5196, and I think I might be able to clarify our issue a little more:
The female PWM connector on the VEX branded Victor 888 speed controllers on the 2014 KOP (I only specify this so strictly because I’ve never seen this issue on other Victors, but maybe I’m just lucky) seems to have a weak/loose connection when inserted straight up in the connector (and the plastic housing ONLY allows a straight, 90* insertion)
When we inserted the PWM cables (the NEW, UNUSED cables we got directly out of the KOP) into the victor, they were definitely going ALL the way into the female connector (you could feel that little bit of extra resistance as they slid in) and looked exactly like the picture you just posted.
They were, however, only giving us a flashing orange/yellow light which means “no PWM signal.”
At first, we thought we were getting no PWM signal from our DS, but connecting up a Jaguar as a test verified that we were, without a doubt, sending signal down that wire. We later ended up building a little PWM signal generator out of a spare arduino and verifying on a scope that it was, in fact sending signal before ruling out everything else except the speed controller itself.
After playing with the connector and trying to get it to detect the signal, we finally gave up and disassembled it.
We then hooked up the speed controller as normal, sans plastic housing, and inserted the PWM cable.
What we found was that the speed controller would only sense the PWM signal when the PWM cable was tilted a small amount.
This means that either
A. The PWM cable pins are too small and don’t properly make contact with the female connector
or
B. The connector is designed for larger male pins and doesn’t make a proper connection
or
C. The male pins on the PWM connector aren’t long enough to reach the bottom of the female connector on the victor
This issue occurred on BOTH of our KOP 888s, so I would guess that it’s either a manufacturing defect on the cables/speed controller OR FIRST gave us PWM cables with pins that were a little too small for the PWM connectors on those particular victors.
Our fix, as previously stated, was to insert solid 22 gauge wire into the connector (which was large enough in diameter to make a solid connection with the female connector in the victor) and put a female PWM socket on the other end of those wires.
