Victor motor contorls flashing orange
The motor Safety is because something is slowing down the cRIO program or the communication packets.
You can run without the Safety if your controls remain responsive. If however you are experiencing any lag, then it becomes a higher priority to track down the cause for the slow down.
The flickering orange/no lights pretty much describe a calibration issue.
On the Dashboard there is a display with a green dot showing one of the joysticks movements. Does that green dot go all the way up or down when you push the joystick all the way forward/back?
And is the green dot centered when the joystick is at neutral?
Begin.docx (254 KB)
Here is a document with a picture of the vis.
Begin.docx (254 KB)
Begin.docx (254 KB)
Is there a reason you didn’t just attach the pictures directly? Embedding them in a Word document requires extra steps on both your end and ours in order for us to see them, and it messes with the aspect ratio and size, making it hard to view them as they were originally captured.
With the exception of disabling the Drive motor safety, it looks like a standard Arcade default robot project. Did you make any changes that aren’t shown, perhaps in Periodic Tasks?
Are there any messages on the Drive Station diagnostics display?
Alan that was my fault as I asked them to paste it into a Word doc. What would be the better way? Thanks
Just a side note since we don’t know if the software is working correctly, performing a calibration to the joystick may, I’ll say that again may make the problem worse.
I would really try resetting the Victors back to the factory default and then see what happens assuming the Victors will respond to the default function as indicated in User manual.
We had a similar problem with two Victors 884,s. They had been used on a practice bot this summer and worked OK. We tried multiple PWM cables driven by a cRIO, VEX and servo tester. In all cases we could substitute a servo for the Victor and it worked OK so we knew the signal was OK to the connector.
We removed the Victors and dissected each one. In both cases we found the problem was the PWM connector on the Victor. We also found a foreign substance on the contact blades. It looked like a glue or conformal coating.
To test we cleaned the three contact blades and attached the wires form a PWM cable. In both cases the controller came back to life.
That concern is very easily handled.
Download the default code and calibrate with that.
The same goes for testing the factory default. It should be tested with default code.
P.S. - to the students-
As a general rule troubleshoot one thing at a time.
Start from a known good position and advance into the problem step by step.
The default code and example code are known good starting points. The factory code defaults if you will.
Verify that the wiring is correct and responds properly to the default or example code before suspecting a code problem.
You immediately cut the list of possible problems in half - software vs hardware.
If your code worked and several things then changed and the robot no longer works, then reverse your changes to get back to a working state and re-introduce the suspect changes one-at-a-time, testing at each step.
I couldn’t figure out how to embed the pictures. But no other changes have been made.
We tried using a new victor, that had never been uses before to see if that was the problem. But it’s light started flashing as well.
I really think you guys should go right bad to square one and start with the default labview code. Double check all the wiring paying special attention to the PWM cables and try it again. Please let us know what happens as all of here really want to see the new teams have something of a working bot.
Please tell us what the ‘RSL’ LED on the digital sidecar does and any errors or things that just don’t seem correct.
After a number of emails with the team I have now found that they have the basic drive back up and running again. The only problem is I don’t know what was causing the problem in the first place so we haven’t learned anything. At least the system is running again and they can move forward :slight_smile:
Thanks to all for the good ideas for them to try.
We’ve been having issues with out Victor 888s as well. After some research we found out that if you shave down the sides of the shroud of the PWM cables they will fit into the holes of the Victors. Our pins were not connecting to the inputs in the victor because the shroud is too big. Vex says that if you are having issues with the Victors than to shave down the sides of your PWM cables. Hope this helps, good luck!
