Hello,
We have a victor spx that is only driving one direction on our lift. The leds on the controller signal that is coded correctly but there is no voltage being applied in the forward direction.
Hello,
Do you call .configFactoryDefault()
or configAllSettings()
on startup? I’ve had issues before with previously configured limit switches were taking effect after swapping the Talon/Victor to a new bot.
Yes what maccopocco said, check your limit switch settings, soft limits, and nominal output settings.
