That’s a one line question that is begs an answer much longer than one line :).
Basic information:
As noted by other posters above: virtualization software generally allows you to divide your computer somehow.
This technology has been around for decades.
That’s a nice simple one line answer. Now let’s get into details:
For the sake of this post: OS = operating system
HVM (hardware virtual machines) create a set of fake hardware that you can install another OS on.
The HVM conceals from the installed OS that it’s passing along requests to actual hardware so it’s often called: full virtualization.
Paravirtualization on the other hand, creates an environment where an OS aware of the paravirtualization can share resources with another.
Finally OS level virtualization creates a situation where an operating system can start more copies of itself with some containment.
Virtualization can be powered purely by software emulation which hurts the computer performance.
Virtualization can be accelerated by hardware built-in to the system processor (Intel calls this ‘VT-x’ and AMD calls it ‘AMD-V’).
Not all CPU support this additional feature, it’s quite common that the cheaper lower end Intel CPU do not have it enabled in the microcode.
When the feature is available generally it can be controlled (at least on and off) in the system firmware (BIOS or EFI).
Some virtualization software can only handle 32bit software others can handle 64bit and 32bit software.
If you intend to run a 64bit OS in a virtual machine it is best your processor and an host operating system support 64bit operation.
On a computer without PAE support a 32bit host OS is limited to 4GB of RAM and, as a result, you’ll be dividing that somehow with the virtualization.
In many cases there is a host or native OS. That’s the OS that basically would still be there if you removed the virtualization entirely (perhaps the copy of Windows that came on the computer from Dell for example). If the virtual machines run without this they are generally called ‘bare metal’ which really means they are running in a very tiny framework designed to just get things going and offer minimal features.
In the case of paravirtualized software there’s also what’s sometimes referred as the hypervisor OS. Xen for example boots a microkernel that starts the hypervisor OS (for example OpenSuse Linux) and then from there starts and monitors all the other virtualized resources. The Xen framework offers the guest OS (a guest OS plural or singular is anything not the hypervisor) the resources of the hypervisor operating system and the Xen microkernel upon which it all runs. In Xen you are not ‘bare metal’ you need the hypervisor operating system. In contrast VMWare ESX is bare metal it needs no hypervisor OS and provides all the basics to pack the computer with HVM.
Some common virtualization software capable of hosting an HVM (probably the most useful for FIRST teams):
VMWare: ESX, Workstation, Player, Server
Parallels
Oracle VirtualBox
Microsoft XP Mode
Microsoft HyperV
Some common virtualization software a FIRST team might find for their web hosting:
(Citrix) Xen (yes this microkernel can be run for HVM on a workstation but most people do not)
OpenVZ
FreeBSD jails
Preface:**
I have 6 licenses of BobCAD mill in my name, 5 licenses of BobArt and 3 licenses of BobNest. That represents versions 21, 22, 23 and 24. The current shipping product from BobCAD is version 26. Shortly I am working on transferring some version 25 licensing to my name as well. Version 22 has a USB key the others do not but require activation. BobCAD often is negotiable about the license cost but if you own BobCAD you probably recognize how much that much BobCAD I just listed would cost to acquire. I did so over the course of years for various CNC projects I built.
So the issue I have is that for me I will not hesitate to take one of the hundreds of computers I own regardless of age and put BobCAD on it in whatever OS is suitable as the older versions of BobCAD do not always work properly in the newest versions of Windows.
However where the school is involved I do not always have the luxury of picking the hardware or software I desire. Often times they are Dell computers with an OEM or educational volume license. These days they’ll arrive with Windows 8 and a free upgrade via the Microsoft App store to Windows 8.1. Anyone that is an administrator that opens the App store will likely be prompted to upgrade Windows. I found that BobCAD version 23 which I put on that sort of computer does not play well with Windows 8.1. It depends on .NET framework 1.1 and an older Visual Studio 2005 runtime that blows up fantastically in that operating system version. It generally installs with Predator CNC just fine. However BobCAD itself will not start properly even if you ‘run as an administrator’ and ‘run as Windows XP Service Pack 3’ per the BobCAD directions. You get an ‘unusual shutdown of the C++ runtime has occurred’ error from MSVCR80.DLL just before Windows slams the executable to a close.
As a Microsoft developer I am aware that there are standing compatibility issues with .NET Framework 1.1 and the Visual Studio 2005 runtime starting in Windows 7 and increasing into Windows 8.1. Patches have been made. Workarounds tried. Warnings during install exist. Still the issues remain.
What does VMWare do for us:
With VMWare I can put a copy of Windows XP Service Pack 3 in a virtual machine. Unlike the ‘XP Mode’ from Windows 7 this virtualized environment from VMWare offers pretty much top of the line graphics acceleration (for a virtual machine). Plus there’s support for passing through USB devices like we need for the Keyspan USB2-to-RS232 adapter we use to communicate with the Haas controller in the mill.
As an added bonus with the virtualized container it is possible to pick up the entire ‘virtual machine’ and move it to other PC (keeping in mind that a change from Intel to AMD virtualization technology is not transparent to the virtualized OS). So if the computer for the mill dies we can just move the data to another and all the details move with it (the tooling settings for the loaded 10 tool umbrella tool changer, the interface settings, whatever other utilities you may have installed, the virtualized OS settings). Literally just copy the virtual machine files to the other PC. Install the proper version of VMWare Player and you are all set. Heck if that virtual machine was suspended when you moved it, usually you can just restart it on the other hardware and it’ll start right back up.
In point of fact it should be possible to pick up the virtual machine from Windows 8.1 as we have it now and move it to a Linux host. Then pick it up from there and put it on Mac OSX. I move VMWare virtual machines all day and this works surprisingly well (of course most of the virtual machines I move are not attached to milling machines…but they do sort of run the economy).
More information:
In this case the Haas mill has a controller and therefore it handles generating the really hard timing requirements for the machine operation within itself. That means that effectively BobCAD can even drip feed G/M code to the machine at 19,200 baud and keep it running.
If the machine required precise timing for steppers that is typically done with the parallel port with or without an FPGA. This makes the PC connected to the machine the CNC controller and in that setup virtualizing the operating system running the timing critical parts is probably asking for trouble.
There is no reason, however, I can’t take a PC acting as a controller with the CNC controller software installed on the native OS (Linux or Windows) and suitable resources and put the VMWare virtual machine on it (with whatever OS is in that virtual machine) so I can run BobCAD to feed the CNC controller in the native operating system. Effectively doing both on the same computer from the user perspective at the same time. From BobCAD’s perspective it won’t really know it’s feeding a program in the native operating system on the same PC.
If I was so inclined there’s nothing stopping me from putting all the versions of BobCAD I own in separate virtual machines each with suitable OS licensing and having them all on the same computer so I can call each one up for use one at a time. Maybe there’s a feature I know how to use better in one version than the other or it just works better in version 21 than say version 24. Then one day dividing those virtual machines out to several machines by just copying the data (so Team 11 just needs to buy 5 more Haas TM-1P and we can test that :)).
An important note:
I have no idea if the BobCAD company would consider this setup supported.
It doesn’t matter to me as long as it works.
If you do this and BobCAD doesn’t like it…well it is what it is.
For me it’s easy to make this issue irrelevant: I do have BobCAD on non-virtualized systems.
Why bother with the students using this:
Virtualization saves: money, time, power and variations on those themes.
It is unavoidable in any large computing environment going into the future.
The cost savings can be enormous.
Even if the systems need every last bit of performance: odds are they do not need to run 24/7/365 so there can be energy savings.
For a student it usually comes down to:
No money for more hardware
No want to trash their existing system doing testing
Easier to run the virtual machine than repartition and reboot over and over
