Hello, Is Vision Assistant suppose to give you results. I made a simple script with color location and a coordinate system and when i run the script it doesn’t show any results. Also when i place the coordinate system on the color loction are the cords 0,0 there at the location of the color or does it give you results based on the size of the resolution
Thanks You
David Elizondo
(Programmer)
