vision camera
Our team needs help puting together the camera. Is there any instructions or websites with instructions to help us?
I assume you meant the pan/tilt mount.
http://robotics.dyndns.org/FIRST_2006/CMUcam2_mount_assembly.pdf
Note that those instructions mean that you will have an upside-down image on your camera. This is perfectly acceptable if you’re using the example camera code from www.kevin.org/frc/ That code expects the camera to be upside down anyway, so it’s ok. Just warning you to expect an upside down image when you talk to the camera in labview.
Other camera support documents can be found here: http://www.usfirst.org/robotics/2006/visiondocs.htm
