Vision Co processing on RPi 3 Help
Hi, I am trying to set up vision for my team using a raspberry pi 3 running Raspian jessie. I have tried to follow the steps on the WPI screen-steps site, but I don’t understand how to actually get anything to run. I have very limited knowledge of Linux and the documentation from wpi assumes that you have some. I need to get this working in the next day. Can someone please walk me through exactly what to do to get vision running?
Just an update, I have successfully built OpenCV 3.2.0 on the RPi, and have built the VisionBuildSamples available from https://github.com/wpilibsuite/VisionBuildSamples and followed the steps from https://wpilib.screenstepslive.com/s/currentCS/m/vision/l/687863-off-board-vision-processing-in-java. What should I do now? I don’t know how to “run the program” or send the network tables to the RoboRIO.
So, I have found the Jar File and I think this is how I run the program, but how do I know it is working?
Ok, newest problem : Exception in thread “main” java.lang.UnsatisfiedLinkError: no opencv_java310 in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1857)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1119)
at Main.main(Main.java:12)
See this thread: https://www.chiefdelphi.com/forums/showthread.php?t=161767
