Vision tracking and camera server rectangle draws in only one spot
I am trying to draw a rectangle on the output based on the detected contours.
What i am getting is it works on initialization and then when you move the target, the rectangles are still in the same place. I am not sure where I am going wrong.
HttpCamera camera = CameraServer.getInstance().addAxisCamera("10.4.96.20");
		camera.setResolution(IMG_WIDTH, IMG_HEIGHT);
		pegVisionThread = new VisionThread(camera, new PegPipeline(), pipeline -> {
			if (!pipeline.filterContoursOutput().isEmpty()) {
				synchronized (imgLock) {
					//centerX = r.x + (r.width / 2);
					//SmartDashboard.putNumber("center x", centerX);
					CvSink cvSink = CameraServer.getInstance().getVideo();
					CvSource outputStream = CameraServer.getInstance().putVideo("Peg Vision", 640, 480);
					Mat source = new Mat();
					//Mat output = new Mat();
					while (!Thread.interrupted()) {
						cvSink.grabFrame(source);
						Rect r = Imgproc.boundingRect(pipeline.filterContoursOutput().get(0));
						Rect r1 = Imgproc.boundingRect(pipeline.filterContoursOutput().get(1));
						Imgproc.rectangle(source, new Point(r.x, r.y), new Point(r.x + r.width, r.y + r.height),
								new Scalar(0, 0, 255),2);
						Imgproc.rectangle(source, new Point(r1.x, r1.y), new Point(r1.x + r1.width, r1.y + r1.height),
						//Imgproc.cvtColor(source, output, Imgproc.COLOR_BGR2GRAY);
						outputStream.putFrame(source);
						// Can do target math here
		pegVisionThread.setDaemon(true);
		pegVisionThread.start();
You have an infinite loop in the pipeline callback, so once the pipeline finds a contour, it will not run again.
Where is it getting caught? I assumed that in the while(!thread.interupted) would continue to grab a new frame and process as long the thread was running.
