Vision Tracking using a common router in Labview
My team is having problems connecting the radio to our robot after this year’s competitions (Someone put a very strong glue on the ethernet cable).So we decide to use a common router we have.Problem is :Vision Tracking doesn’t work without the use of the radio for some reason.
Is it possible to make vision tracking with the use of a common router???
Without knowing how you are doing vision tracking (GRIP on the dashboard? A coprocessor? Onboard the RoboRIO?) it’s not really possible to help you.
I seriously doubt it’s impossible without the radio.
ooops my bad.I am using Vision Assistant from National Instruments and a WebCam connected to roboRio by a USB Cable.
Flash your radio on your own computer its probably still flashed for the FMS
