vision tracking
Team #3998, Redneck Robotics is trying to use vision tracking of the yellow totes in autonomous. We can track the yellow color of the tote, but cannot get the same results when the camera is hooked up to the robot. We have the VI, but the can’t integrate it into the code. Any ideas?
Did you follow the tutorial on vision? One section described how to integrate it into the roboRIO’s code. If you followed it and had issues, where? You may also want to post pictures of the code.
Greg McKaskle
Did you linked the Vision Vi into the Dashboard Main.Vi already? Try to get the error output and figure out if everything is working. I figured out that way that the path for the reference image for Shape match was not working.
