Vision VI error in Robot Main VI
We are getting the following error with our Vision VI. The vision VI is the example VI that we imported into our code. We have tried fixing all the wire connections and we have had no luck getting the error fixed. Any help would be greatly appreciated.
The inputs declared on the front panel of your Vision Processing.vi appear to have been tampered with.
Open the front panel and look in the upper right corner.
The white square divided up into smaller boxes.
There should be a blue little box and a greenish/gray little box.
These are associated with front panel items *Image Size *and *Error In *respectively.
Error In is required, but if Image Size is the one missing, then you can just delete the feed in Robot Main if you want.
Thank you, that worked.
Right click=>relink to SubVI. Works like a charm. But, since you already deleted the linkage to Image Size, be sure to just set your image size and save it in Vision Processing.vi.
Also, after bag and tag, you can import my profile pic-it’s the actual icon I use-for a little fun.
