hello
when we run the program on our robot the volts Values stays on 0.00 … what could be the problem?
You probably either did not connect the wires from the power distribution board to the analog bumper, or you did not add the jumper on the analog bumper.
umm… where does the jumer goes? I mean on the analog there are several pins…
wich should i use/cover…?
In the picture on the first page here you’ll see the entire analog breakout. In the top left corner of the image there are 3 exposed pins, spaced so they would fit a normal PWM wire. Place a 2-pin jumper over the two pins on the left of the picture - in other words, the two pins closest to the side edge of the board.
