Volts.
the VOLTS output on my driver station, is not being updated. It’s stuck at about 17.5 volts.
Are you in compliance with [R64]?
… and [R36] paragraph 1 :slight_smile:
Okay great ill try it out. I have found this - http://frc-manual.usfirst.org/viewSingleItemMap/705
is that what your referring to?
EDIT:
We do have this installed and setup. Still have no volts.
Try a different analog breakout. That sounds like the reading you’d get if one of the resistors in the battery sense voltage divider is open or missing.
okay we will try it.
I ran into a team with this issue during an inspection last year. It was discovered that they wired the 24V from the PD to the analog bumper instead of the solenoid bumper. I believe that they had pulled the cRio as part of thier witholding and accidentally swapped the connectors when reinstalling it.
