I have found an issue with my installation of VSCode 2020. it seems that upon creating the example project the main files have incorrect encoding and end up being a garbled mess of this character: �
does anyone know how to solve this issue?
Open the command palette, and run the Change File Encoding command. Then select reopen with encoding, and select UTF-8. That should be automatic, so its weird that its not. But that should fix it.
What OS are you using?
I ended up simply deleting the project and remaking a new one which ended up working just fine. Must’ve been some odd rare issue that had caused it, thanks though!
