I know that this can be confusing so I am going to make a stab at this. The MK battery charts are generalized, guaranteed specifications for a new VLRA battery. The company has set these standards for the entire line and the graphs are plotted for Amp Hour vs discharge current rated in C where C = the rated discharge rate in amp hours. For our battery C=18AH. The MK Company charts are published on their website for VLRA batteries. The curve we have been looking at is a converted chart where the C values have been converted to discharge amps. .1C=1.8 amps, .5C=9 amps, etc.
For Team 111, the CBA tester is then set to it’s maximum current (for this model) of 7 amps. Each battery, each year, is then tested at the beginning of the build season and the curves saved for each battery. If a battery tests out at 15 AH or above for the test, it is considered good enough for competition. Anything under is marked for “practice only”. If there appears to be cell failures as shown previously, the battery is recycled. Failures of this type can be frustrating to team members and I fear can cause damage to chargers. I might be persuaded to run higher current testing if I were to purchase the higher current model CBA but I would not test at anything above 18 AH rates to maximize battery life (charge/discharge cycles). This testing does duplicate published company specs and curves leading us to group like batteries as healthy enough for competition.
As noted, even bad batteries can show normal terminal voltage before a cell(s) fail. Don’s test, however, would also fail when testing a similar battery.
In Don’s test, as pointed out by Alan, the current is much more than 12 amps. It is however within the realm of current drawn during match play. By performing this test, Don’s team has been reasonably sure that the battery will survive a two minute match. I would agree, but point out that max battery life will suffer. The kind of current drawn during this test is beyond the current drawn by most FRC robots during a similar time period. An FRC robot might draw this current in a failed autonomous run where the robot is pushing against a wall or other barrier for the entire auto period. It is possible to draw this much current on an FRC robot as the 120 amp breaker will not trip. It is possible to draw up to 600% of the rated current for several seconds without a trip on this breaker.
Don and I are both amateur radio operators and a familiar term for us “key down”. In our hobby we relate “key down” time to the average battery usage of portable operation. It is usually calculated by a percentage of actual transmit time (high current) and receive time (low current) operation. Many of us have discussed using this analogy for FRC robots but unfortunately, there is no standard robot for which to make predictions. In either case, both of our testing, although possibly flawed, can predict with some certainty that a battery so tested will survive a two minute match. Simple voltmeter testing, very high current load testing (car battery handheld load testers) for seconds, and short driving tests will not guarantee a battery will last a two minute match plus auto.
It is also a problem when people quote sections of the manual out of context. For instance, the maximum current specification on this battery is 720 amps for several seconds. Note that terminal voltage is not specified here. 720 amps would drop nearly 8 volts across the internal impedance of the battery. It is why the designers of the PD made two boost buck regulators to feed the Crio and wireless access point. High current demands would shut down these two critical systems without the additional power supplies rendering the robot useless for most of the match.
Updating previous post with new info:
- Don suggested applying a 12 amp load for 15 seconds and measuring the voltage under load. Above 10 volts is Very Good. 29
It was apparently a typo. Don meant 0.01 ohm, not 1 ohm. [edit]Don did not mean 0.01 ohm. see his new post.[/edit]
But with 10 volts across a 0.01 external resistance, the load would be pulling 1000 amps… and that raises two problems:
Fifteen seconds of that could potentially damage the battery or lessen its life. It would also probably burn up or damage a 25 watt 0.01 ohm resistor.
The battery can’t supply 1000 amps at 10 volts. Its internal resistance is too high*.
Perhaps the resistance of the copper wire is increasing due to heating. Let’s say the wire gets boiling hot (100C). That’s a dT of 80C, which would increase the wire’s resistance from 0.01 ohm to 0.0132 ohm. At 10 volts, that would be 758 amps. Still too high.
Perhaps the test depends on additional external resistance, maybe from a switch that is used to complete the load circuit? (I hope someone is not just holding the wires and jabbing them into the battery terminals :eek:)
Don, do you guys have a clamp-on ammeter? Could you record the actual current draw next time you do this test and post the results?
Bottom line: Don’s test is certainly severe enough to challenge even a brand-new battery. I worry a bit about safety, though, and battery damage. Do not attempt this without competent training.
- Ether cited the battery discharge graph in the datasheet for the FRC battery which shows 12 volts after 16 minutes at 18 amps. 31
- Joe stated that the voltages in the datasheet graph are taken open circuit. 33
Still not 100% resolved, but I think this is one of those rare times that Joe is mistaken.
- Al’s 7 amp graphs show a healthy battery still reading over 12 volts (under load) after 43 minutes at 7 amps. Even a very sick battery (blue line) still reads over 12 volts (under load) after 17 minutes at 7 amps. 30
All true, I think.
*the internal resistance of the battery drops as the temperature increases, but not enough to allow 1000 amps without damaging the battery.
OK, Maybe this’ll help. Maybe not.
I meant 1 Ohm, not 0.01 Ohm. 1000 Amps would be nifty, but impractical.
Spark-free, safe & effective uses the 120A main breaker to bring the load online. We wired everything (including voltmeter leads) to a PowerPole battery connector for simplicity. I am using a 1 Ohm, 125 Watt resistor I ‘happened to have’.
Alan, of course you’re correct. if 10 feet of #10 had 1 Ohm, my house would’ve burned down years ago. And none of the power outlets would deliver more than, say, 20 or 40 volts AC. I just wrote what came to mind, and obviously I was off by at least 2 orders of magnitude. :o And, since 1000 feet of #10 isn’t usually just hanging around most shops…I’ll just suggest finding a 1 Ohm resistor somehow.
Ether, you asked where did those numbers come from? Empirical results over the years, specific to FRC batteries. These are based on recommendations from the Battery Council International (BCI), but they’re dealing with automotive batteries being tested at somewhat higher rates and so their data doesn’t directly apply here.
Lastly, a comment on the glass mats used in “Absorbed Glass Mat” technology batteries: Think of compressed fiberglass insulation, that’s what the mats look, feel and taste like.
Of course, you all know beyond a shadow of any doubt that** I am an idiot.**
I re-read Alan’s comment, and of course: 1 Ohm (12 A) shouldn’t bring any FRC battery down to 10 volts any time soon. I mean, how would we survive a 2 minute match?
I just wish I could delete all I wrote in this thread and just start over.
I promise to rely less on memory and focus more on reality in the future. I am mortified and embarrassed.
Don
Ether, I’d best say that I just pulled those numbers out my (you know). They’re not even that good. What the #311 was I thinking?
Don
Boy Don, it’s been a day and a half since you posted that and noone has stood up for you yet? I guess you know who your friends are…
I’m really glad you threw some ideas on the table, regardless of their accuracy. When I first posted I was looking for and expecting a short answer, but looking at the details that teams are going through to test out batteries has really got me thinking. Like a true M.E. I just figured it was a box of electrons with no moving parts and how much could possibly go wrong? I’ll never take the batteries for granted again.
You haven’t see the private notes of encouragement
Me too. It inspired me to think about this and do some research.
Nah, Don is just mature (see sig) we all have our moments and we all are still learning. Cue cheesy sitcom ending
Thanks folks. :o
But the bit about using the master 120A breaker as a switch and wiring it up is all true. Honest! :ahh:
You might as well use it as a switch, 'cause it will never trip during the course of a match, unless you’re drawing 150A the ENTIRE TIME.
http://www.bussmann.com/pdf/15e0468b-2837-4360-aeb8-6d391d3f173b.pdf
