Warning stting up a camera in a robot (java)
what does it mean the warning “The method getinstance() from the type CameraServer is deprecated”?
It means the method is no longer supported. Depreciated methods have the @Depreciated tags on their method. The method should also be crossed out in IntelliJ I believe. You can still continue using the method but there is generally a better way.
In this particular case, the cause is that you’re using edu.wpi.first.wpilibj.CameraServer instead of edu.wpi.first.cameraserver.CameraServer. Just change the import and that should get rid of the warning.
Thank you!!! It helped a lot
Thank youuu
