We’re having watchdog errors. We thought we’d isolated the problem to the camera, then to the driver station switches, then to the third joystick [heh], but we’re still having issues. Using WindRiver.
- We want to disable all User watchdogs, in order to see if we still get watchdog errors (ie, System watchdog/communications problem).
To this end, in the constructor we used GetWatchdog().SetEnabled(false).
Does anyone have experience with/opinions on troubleshooting System watchdog errors?
- Then we learned about the MotorSafety class, which apparently replaces the User watchdog this year. This was hidden away in the documentation at FIRST Forge and I haven’t seen any threads on CD about it yet. Does anyone have any info about MotorSafety, MotorSafetyHelper, and how to work with or disable them? I really wish the documentation had more updated info about working with watchdogs for the 2011 season.
We used robotDrive->SetSafetyEnabled(false) to disable the MotorSafety on the drive motors: to be safe, we even disabled the MotorSafety on our manipulator Jaguar, which supposedly is automatically disabled anyway.
Can anyone help us to disable all watchdogs? I can post/PM our code if you like.
- We suspect the router. We’re pretty sure our watchdog issues started after we replaced the old bridge on last year’s bot [which we’re prototyping everything on] with the DAP router. We don’t seem to have watchdog errors while running tethered [we’re going to test that more tomorrow]. Has anyone encountered watchdog/communication errors with the new router?
Also, we have a Jaguar mounted RIGHT next to the router: does anybody have experience with motors causing interference? Our issues also seemed to start right around the time we began using that Jag, but it’s just a hunch.
Thank you so much for any help you can give!! We really really appreciate it
We do have some pneumatics, would those count as watchpuppy-whelping actuators as well? Well I should be able to dig into the WPILib sourcecode and find out easily enough.
