We are trying to use the built in acceliometer
Hey we are trying to use the built in accelerometer but we don’t know how. How do i make an instance of him and how can i see his value ?
by the way we are programming in java.
You can see how to do this at this page Accelerometers - Software — FIRST Robotics Competition documentation (wpilib.org).
// At head of robot class:
private Accelerometer accel = new BuiltInAccelerometer();
// In for example autonomousPeriodic():
double angle = Math.toDegrees(Math.atan2(accel.getY(), accel.getZ()) );
// .. then use that angle to for example move something to level the robot
The problem is that the built-in accelerrometer is measuring exactly that, the acceleration.
If the robot it tilted while at rest, you get a good tilt angle. But when moving, you have a lot of “noise” on the signal. A CRTE ‘pigeon’ for example gives a much more stable reading of tilt angles.
thanks a lot
