Website technical question.
I have searched far and wide for an answer to this but i have not been able to find one.
My problem is, i am working off of last years website which has a great template, but its off center.
the typical <center> </center> and various css methods have not worked.
I believe this has to do with the way the website is built, but there needs to be a way to do it.
here it is for reference:
Devil tech website
Thanks in advance,
Sean.
I believe the problem comes because all of your repeating:
#apDiv1 {
position:absolute;
width:620px;
height:150px;
z-index:1;
left: 12px;
top: 17px;
the “position:” tag generates an absolutely positioned element. And since they are positioned relative to the first parent element, they are probably piling up from top left down. I don’t really have any suggestions about how to fix that, because I am not sure if removing the absolute from all those would throw off the look completely, but I guess you could start there.
i believe it has to do with positioning everything relatively.
I’ll mess with it and see if I can find an easy fix.
Add this div wrapper inside the body tag
<div style=“width: 622px; margin-left: auto; margin-right: auto; position: relative;”>
disregard this post.
Wow that helped quite a bit! Just looks like there’s a few more things that must be centered but il take a whack at it. Thanks!
