We’ve just assembled our electrical board and we’re having some really really strange issues with the Jaguar.
The Jaguar (currently we only have 1 attached) is connected to the digital sidecar on PWM1. By initializing a new Jaguar via Jaguar j = new Jaguar(1); I can’t control the Jaguar and it blinks yellow after enabling the robot.
However, if I initialized the Jaguar using new Jaguar(4). It works flawlessly (except for the whole wrong channel number thing)…
FIRST released an update a while ago that addressed the issue. Apparently, most of the KOP cables that connect the cRIO to the digital sidecar this year aren’t properly wired. Here’s a link to the update and to the fix:
We have been having the same issue the last few days. Using a multimeter, we did not see voltage on the PWM pins.
I did some additional research last night and found that the slot arrangements on the CRIO have changed, and may have to be accounted for when constructing the jaguar.
If I remember correctly, the digital sidecar needs to go in either slots 2 or 6 this year, if it is in slot 2 your code is fine, but if it’s in slot 6 you must modify to:
Jaguar j = new Jaguar(2,1); //the channel must be 2 for a digital car in slot 6.
(note: I’m programming in C++ and this is valid, but you may want to make sure the channel is the first param for Java)
I haven’t had a chance to test if this resolves our issue, but I’ve got a good feeling :] hope this can help.
