West Mountain Battery Tester
We’re looking at a more reliable method of ascertaining battery performance this year. As far as I can tell, the West Mountain Battery Tester looks like ‘best practice’ based on what people are using and recommend.
http://www.westmountainradio.com/cba.php - which model is the one that is needed?
There is an excellent paper on a testing method outlined here: https://www.chiefdelphi.com/forums/showpost.php?p=1455013&postcount=1
which does not use the west mountain tester. Has anyone outlined an effective test procedure using the West Mountain tester that we could utilise?
https://www.chiefdelphi.com/forums/showpost.php?p=1218604&postcount=1 indicates:
“constant discharge rate of 7.0A down to 11.0 volts.”
http://team1640.com/wiki/index.php?title=Battery_Testing:
CBA III (previously a CBA II - Computerized Battery Analizer) from West Mountain Radio. The CBA performs a discharge test at fixed current (7.5 A), tracking voltage. The test terminates at a cut-off voltage (10.5 V) and the total Amp Hours (A hr) are reported. More A hr is better. FRC Batteries are rated for 17.2 A hr and this test returns values in the 13-16 range for good batteries. The test requires about 2 hours and discharges the battery. Because of the time investment involved, this test is run infrequently and is not useful for testing batteries in competition. It does, however, identify batteries with dead/shorted cells very clearly.
Is there anything else we need to know?
We use a CBAIV to load test all our batteries.
When you figure how much each match you play actually costs you it’s a cheep investment.
Just got done testing our old batteries. Results led us to retire our last 2 2015 batteries and relegate 2 of our 2016 batteries to practice/scout batteries status all 2017 still going strong at this point.
We will test them again before going to competition to see what batteries we will use.
We used a CBA on 865 and it was pretty astonishing how differently each battery preformed. We had some 3 year old batteries that preformed better than new batteries in the total discharge test. While it won’t tell you everything pairing the CBA’s data with some anecdotal drive testing for maximum discharge will give you a very good idea of battery health. Our testing procedure was to discharge each battery fully at max current. With roughly 12 batteries total we’d then take the top 4-6 and save them for comp, dispose a couple of the poorest preforming ones and keep the rest for general use.
Please specify what you mean by “discharge fully” and “max current”.
What procedure are you using for load testing?
I recommend the CBAIV as well. I set it to run a 7.5 amp test to 10.5 volts terminal voltage. That test should take about two hours per battery and return an amp hour rating of 12.5 AH or higher. The graph will return https://www.chiefdelphi.com/forums/data:image/png;base64,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something that closely matches the manufacturer tests for the same current.
The graph below is a typical FRC battery discharge chart. Approximate a point between the the 4.4 and 10.86 curves and you will cross the graph at about two hours. Please note the smooth graphs during discharge. If your battery drops by two volts anytime during the test, you have a bad cell. Recycle please. Any battery that tests between10 and 12 AH use for practice only. Anything less than that, recycle. I made an adapter from 35 amp power poles to the SB50 for testing. Once you save the test for each battery you can make a test in the future and then overlay it to see any changes.
Excellent - thanks for everyone’s help. It will be interesting to be able to quantify battery performance.
