Consider a couple things before doing a ramp:
The top of the platform is 104" in wide
As Roboshant pointed out, the smallest full-size robot is 34.5" wide with bumpers. Three robots like that is 103.5" which does not leave much room for a double ramp in even the best scenario.
If you’re planning on staying on the ground, you better be able to lift both robots otherwise you’re merely relying on cooperation to lift someone in your place.
At lower competitions lifting two robots in your place will be useful as a majority of bots will have a hard time climbing. Once you start getting higher up, at least one other robot should be able to climb, which goes back to you trying to cooperate to lift someone in your place.
I do like the idea that if you can lift 240 lbs SAFELY and RELIABLY every time (yourself and one other), then you will be valuable even at higher levels. This is one of those things I really only expect from a power-house team.
