What are Teams Thinking for Multi-Climbs
One thing that has not been mentioned in this thread is the that 3-robot-climb bonus goes away in Elims. You get an extra ranking point during Quals, but nothing extra during Elims. This raises a strategic question: is worth getting the 3rd robot to climb, or is it worth more point to have it on the field trying to influence the scale/switches. If you can tip one of the balances at 30 seconds before the end, while the other alliance is busy setting up a big climb, then you have gained 30 points, same as a climb.
I think the “Iron Cross” will be quite popular with the top 3% of teams for the extra RP in quals. It’s definitely not something the other 97% should be worrying about though. Tons of engineering effort that isn’t as valuable as the much simpler tasks like scoring on the scale or switch autos.
Would it be worth preparing a cheesecake ramp for elimination to make up for not having a triple climb robot on your alliance? While it might be difficult to design a ramp every team can climb up, it is probably easy to make a ramp your own robot can climb up instead.
My team is going for the strategy of lifting ourselves and one other robot and the third robot gets the levitate. This leaves that last robot to keep doing switchs and scales for the last 30 seconds but still achieves 3 climbs.
I think that very few teams will attempt the Iron Cross, fewer still will end up with a mechanism that can do it reliably, and the tiny fraction that’s left will usually have alliance partners that don’t manage to get where they need to go to pull it off. Double ramps with levitate (or single ramps with one actual climb and levitate) will be fantastically more common and more reliable Face the Boss RPs.
In terms of the robot you want to build, if you’re going to go for specialization rather than an all-rounder, the vast, vast majority of teams would be better off building a dedicated vault/switch bot that can neither score on the scale nor climb at all. If all you do is tackle your switch (135 teleop points, ~28 autonomous points + 1 RP) and feed your vault (45 cube points, 30 climb points, +10-20 points for Boost, +10-20 points for Force for a guaranteed 95 and potential 115 points, 10 of which overlap with switch control), you’re looking at ~60% of the maximum possible score of every game and your share of both bonus RPs.
Filling the vault is worth more than a Face the Boss to the tune of 5-25 points, and it’s an astoundingly easier engineering challenge than an Iron Cross.
Teams amaze me ever year with what they manage to pull off, but for every team that pulls off the amazing, there are hundreds that can’t really play the game to any real level of effectiveness because they tried to pull off the amazing and fell short, rather than focusing on the best robot they can actually build and get practice time on. (Like, say, us last year.)
I completely agree this seems to be the more reliable way to go due to less factors that need to come into play. Some key factors to look into:
I.E = 1. “Iron Cross”, “Upside-Down T” etc - balancing out weight on both sides of robot to be able to lift, compensate for weight differential, a strong enough motor(s) to be able to lift all robots.
     2. Ramps- Wide enough for all size robots to climb onto, Can support up to 120lbs+ and have the bumpers "levitate" past the 12" mark. Support for 2 other robots.
I know we are a rookie team but we are going to have a linear climbing mechanism to lift our robot about 4 feet off the ground. We are looking at possibly installing a rung underneath our robot so that another team could hook on and lift. Thoughts?
You have to remember most climbers are calibrated to possibly climb on a game rung at game height so engaging on a lower rung securely could be problamatic for some possibly many teams climbers
Also a rigid structure under your bot may not keep your bumper height under 7.5" (bumper zone still applies in endgame IMO)
I think this is why ramp bots seem desirable somewhat easier solution to park on a ramp although High CG bots on a ramp that a recipe for disaster. The other option is to mimic the actual rung (could make it wider) this could also be 3.5" lower since a back climber possibly engage from carpet. Side climb have to worry about balance issues.
The other theory is to use ropes or other flexible stuff (see Q&A #4)… since many teams had rope other flexible stuff climbers in 2017 and would have those laying around.
of these are probably more Einstein than normal games, I don’t expect to see a lot of successful physical Multi-climbs, its hard enough to park 3 bots in 104" with bumpers
My general feeling is this game will be signficant wear and tear on bots (auto collisions, high GG falls tips, defense hammering, ramps/proectors, banging into scale plate wall and switch wall) just a slice below Stronghold…so think durability and spare parts
Another consideration is that many robots will have arms and elevators which would need to clear the bottom of your robot if they were to hang beneath it. It will be tricky to say the least…
Is any offering of a “Buddy Bar” better than no offer? I would believe so.
That’s what a lot of people thought in 2010. However, few teams actually did, and AFAIK one was only ever used once. That said, the incentive to use one was very low, unlike this year.
Keep in mind that if you add a bar, you need to be sure your climber is strong enough to hang another robot plus some impulse force when latching. If using the bar breaks your climber, you just turned 30 points in to 0 plus a broken climber.
I would also add that if you fall you will be very unpopular with the team who’s robot you decimate below you.
With the right sensors and independently controlled winches instead of just the one we used on the Ri3D build. We think it is possible.
I definitely think if a team is going to try to build the “iron cross” that it needs to have some serious over-engineering. I definitely wouldn’t want to be the team responsible for dropping another team’s robot. We did serious stress analysis in Creo to determine if the idea was even viable before we ever cut a single piece of material.
Teams attempting to balance only one robot without a counter weight do have the Tower itself to brace on, or at least the two inch lip as shown in Figure 3-10 of the game manual.
Image of the lip is attached. (Not sure how to show it in the post without uploading my snip to imgur or something).
Also locking your hooks into the bar would potentially solve the tilting problem too with only one robot on the “iron cross” or as I call it…the “robot elevator”
Perhaps one could additionally brace under the extension part of the rung for side support, or else latch around the bar and have some sort of quick release for removal post-match. The issue I see is tipping, which is why a passive (gravity-reliant) open hook isn’t likely to be reliable for said iron cross. Having support both over and under at 2 or more points will help alleviate that.
I think it’s doable, and at higher levels of play I think will be a game changer, especially if scoring gets to the point of power cubes being a scarce resource. Time will tell, and I look forward to see if anybody tries it.
I think you are slightly forgetting you cant push downwards with pistons or else your bumpers will violate the 2.5" height restriction! Other than that, its a solid strat.
WOOOSH
Actually, you just got WHOOOOSHED :cool:
