What is CAN?
Hello,
     I have no clue how to use the CAN bus. We got Talon SRX I'm not entirely sure what to plug the CAN wires into. If anybody has a diagram that would be great.
I’m going to point you to the manuals for all the control system hardware here: https://wpilib.screenstepslive.com/s/4485/m/24166/l/144968-2016-frc-control-system-hardware-overview The wiring instructions on this site have some help for wiring CAN.
The CAN bus is designed for you to daisy chain all of your CAN related hardware together, and requires a terminating resistor at the end of the chain. The PDP has a terminating resistor built in and can be used to end the chain if that’s convenient, or you can move the jumper to the other position and use something else at the end.
Complete wiring instructions for Talon SRX can be found in the User’s Guide.
http://www.ctr-electronics.com/talon-srx.html#product_tabs_technical_resources
