What is this error message?
003A00 FD 0E DB 50 80 0B 2B 10 C0 6E FC 0E DB AE 03 D0
003A10 9E 9C 9D 8C F2 8C C2 80 E5 52 E5 CF DA FF E7 CF
003A20 D9 FF 12 00 50 6F 72 74 31 20 59 20 25 33 64 2C
003A30 20 58 20 25 33 64 2C 20 46 69 72 65 20 25 64 2C
003A40 20 54 6F 70 20 25 64 0A 00 25 73 0A 00 49 46 49
003A50 20 32 30 30 35 20 55 73 65 72 20 50 72 6F 63 65
003A60 73 73 6F 72 20 49 6E 69 74 69 61 6C 69 7A 65 64
003A70 20 2E 2E 2E 00 28 6E 75 6C 6C 29 00 FB 0E E3 CF
003A80 F6 FF FC 0E E3 CF F7 FF FD 0E E3 CF F8 FF FE 0E
003A90 E3 CF E9 FF FF 0E E3 CF EA FF E9 CF F3 FF EA CF
003AA0 F4 FF 09 00 F5 CF EF FF EE 66 FB D7 12 00 FE 0E
003AB0 E3 CF E9 FF FF 0E E3 CF EA FF F3 6A F4 6A EE 52
003AC0 03 E0 F3 4A F4 2A FB D7 12 00 D9 CF E6 FF DA CF
003AD0 E6 FF E1 CF D9 FF E2 CF DA FF E6 52 E6 52 C3 50
003AE0 DF 6E 01 0E C4 CF DB FF DE CF 2B F0 DD CF 2C F0
003AF0 2B C0 F3 FF 2C C0 F4 FF E5 52 E5 52 E5 52 E5 CF
003B00 DA FF E7 CF D9 FF 12 00 1A 6A 19 6A 10 0E E7 6E
003B10 D8 90 1D 36 1E 36 19 36 1A 36 22 50 19 5C 23 50
003B20 1A 58 05 E3 22 50 19 5E 23 50 1A 5A 1D 2A E7 2E
003B30 F0 D7 12 00 45 EC 10 F0 A4 EC 0C F0 01 01 98 91
003B40 01 01 98 A1 07 D0 17 EC 0D F0 01 01 79 AD 02 D0
003B50 9C EC 1B F0 F2 EC 1B F0 F3 D7 12 00 16 EE 00 F0
003B60 26 EE 00 F0 F8 6A 26 9C A6 8E A6 9C A1 EC 16 F0
003B70 FB EC 1B F0 9A EC 1D F0 F9 D7 12 00 FF 0E E3 50
003B80 37 6E 48 0E 01 D0 4C 0E E7 6E E7 2E FE D7 E7 6A
003B90 E7 2E FE D7 37 2E F7 D7 00 00 12 00 FF 0E E3 50
003BA0 E8 4E 12 00 00 00 00 D0 00 D0 00 D0 E8 2E FA D7
003BB0 12 00 C2 90 9D 9C 12 00 C2 82 12 00 00 00 00 00
We thought we had everything working. This is the FRC Code 2005 2.2, when we send it to the robot via IFI we get that error. What is it? Also note that the ifi is able to send last years code fine. Our compiler version is 2.4.
Thanks-again.
Looks like a core dump to me. I’ve seen this happen on older computers (which have slower serial ports) or a computer using a cheap USB to Serial adapter. Loading some files (such as the old default code) will work, but files over a certain size will fail.
If possible, try loading your code from a faster computer.
Where did you see this “error message”? I imagine it must show up in the IFI Loader’s terminal window. What version of the loader are you using?
I agree with Zan that it looks like a memory dump. Exactly what file are you downloading? I haven’t been able to identify a “FRC Code 2005 2.2”.
The infamous notepad core dump. If I remember rightly it actually pops up in a new notepad window.
The only time I’ve seen it happen on pure default code was when you’re using the 2004 original version of IFI_loader v1.0.5 (in IFI_Loader click on “About” to see the version #). The original had a bug that only allowed it to download 16K instead of the available 32K. Make sure you’ve downloaded the latest from the IFI site.
I’ve seen it occur usually due to running out of RAM or data memory, but that won’t be the case with the default code.
Translation: You’ve added too many new variables and used (in total) more than the 1800 bytes the controller has available.
