What order shoud the gear sets be installed on a VersaPlanitary gear box
If installing multiple stages what order should they be installed?
Lower reductions (3:1, 4:1, etc.) should be near the output shaft
Put the higher ratios close to the motor.
Reason is because your higher load is at the output, and lower reduction stages can handle higher loads.
