What pneumatic valve do we use with EVO shifters?
Basically what the title says. We just got them and I’m thinking I’m using the wrong valves. I was wondering which ones do we use/what type. Thanks!image
Last year we used a standard double solenoid, however you could use a single acting solenoid, as the piston on the evo is spring loaded in one direction. You would just need to make sure you plumb to the corect side.
Because of how the piston works you mean add a T connector between the piston and valve to have a exhaust?
Or am I thinking of a different valve
So you can conect the pistons together with a T, then to the double solenoid valve.20200228_200501|465x500
