What Sensor is on your robot drive system?
Team 354
Mecanum drive
no sensor
mecanum wheels
banbots 56mm planetary gear boxes (x4)
banebots wheel encoders (x4)
purchased from banebots
Jacob
Toltechs 0499
Six wheel drive with IFI traction wheel in the middle and then AM Aluminum Omni wheels on the corners.
2 Cims /w 2 to 1 adapters with BaneBot kit transmissions per side.
Banebot encoders:cool:
Team 662
6 wheel drive
Custom gearbox
US Digital encoder
Team 228’s 2007 robot:
Six wheel drive; custom aluminum 5.5" traction wheels
2x CIM adapter Banebot 12:1 transmissions (with hardened DD plate and welded pins)
2x gear KoP tooth encoders (one per side), 1x KoP accelerometer, 1x 300 degree/second gyro (Spark Fun electronics)
Team 1089 - Mercury
4 wheel drive - 7 inch wheels traction tread
2 Andy Mark 2-Speed Servo Shifter gearbox dual cims
2 US Digital encoders H1-50
Worm Crab Drive
Gear Tooth Sensor x2
Potentiometer
Unknown Source
Team 1024
ZTR-type RWD differential drive system.
US Digital Analog Encoders w/always on servo algorithm providing for automatic stability enhancement and higher accuracy positioning by the driver when close to the rack.
Custom gearboxes w/dual cim input on each side for a max velocity of 14ft/s and a max acceleration on flat FIRST regulation carpet of 7ft/s/s.
-q
1138
Mecanum Drive
Greyhill encoders
1103
2 Wheel/with casters
Tested KOP gyro for autonomous
930
Mecanum
optical encoders, don’t know what kind, 100 tick per rotation
Team 330
6-wheel dropped center, AM 2-speed pneumatic
1 continuous-turn potentionmeter per side
Gyro
Team: 118
Drive system:Crab Drive (Swerve Drive)
Sensors for the drive system: 4 Continuous potentiometers
Comments:We used 2 sets of two continuous potentiometers coupled together to get full values from 0-359 degrees on two steering motors.
Team 116:
6-wheel drive
2-Speed AndyMark Pneumatic shifters
Accelerometer
Gyro
Team 701
6 Wheel Drive, 2 KOP Wheels on Centers, 4 AM Al Omnis on the outsides.
BaneBot 12:1 Trans w/ Dual CIM adapters
Greyhill Encoders 63K Series, one per side
Team 1618
6WD, kitbot-based, six AndyMark FIRST Wheels with the original material swapped for roughtop (middle and rear) and wedgetop (front), driven by two AndyMark Gen2 Shifters (pneumatic) running the large and small CIMs.
No sensors.
980
We use the West Coast Drive.
For this year and the last several years we use optical encoders. This year we used the BaneBot encoders (on the AM gearboxes). In the past we’ve used the Grayhill encoders, or other encoders (I think we’ve used different encoders each of the last 4 years – they all seem to work about the same). We also use a gyro.
We also use lots of other sensors on our robot, but that’s all for the drive.
Team: 703
Drive system: 14 Wheel, Tank Style Drive (custom wheels), with custom 2 speed Pnumatic Shifter.
Sensors: 2 Optical Encoders with custom made Digital-to-Analog converters (to simplify programming and wiring; don’t ask me how it works, I have no idea). :smiley:
Team: 1346
Drive: Mecanum (Andy Mark + 4 CIM/BB 56mm 12:1 direct drive)
Sensors: 4 Banebots Shaft Encoders with card
3 Maxbotix Ultrasonic Rangefinders (Tried IR, but it was unreliable on the shiny diamond plate.)
1 CMU2Cam
1 Resistor (Arm)
1 Limit Switch (Lift)
1 Micro switch for tracking lift elevation
Team: 190, Gompei and the HERD
Drive: 6wd
Sensors: 1 KOP Geartooth per side, never implemented to my knowledge
Team 1824
4 wheel skid steer.
Each wheel has 1 small cim into a banebots 56mm planetary gear (with 16:1 upgrade)
Pneumatic 7 1/2 inch tires
No sensors.
