What to upload for RPI Vision
rpi
vision
Hey guys. I’ve created a vision pipeline using GRIP and I’m also writing a client side application for it to read the values. Now I’m on this screen here:
Capture
And I don’t know what to upload to this. Do I upload my vision pipeline? Or do I upload my client program? Also, how do I export either of them as a JAR file? Thanks
E: Grammar/clarification
Build the program using gradle. That compiles it into a single .jar file. You’ll find it in the directory/build/libs/-all.jar
then, upload that file
What program do I build? The pipeline or the client side program?
They should be built together. We may be envisioning separate things, but for us the pipeline is inside of the raspberry program itself.
If your pipeline has a main method, then you should build that.
Just download their example program, implement your pipeline inside of it, and use gradle to build their example.
For example, our Github account has a vision project that can be built and run on the raspberry pi. It only draws a circle on the dead center of the image, and outputs that to a secondary camera stream so you can see the modified image.
Feel free to use it. With regard to your GRIP pipeline, you just need to include the logic in your process() method (and include any supporting functions your pipeline calls).
Thanks. I’m trying to access your GitHub repo but I think you have it set to private.
Sorry about that, try again. Public now.
@Uberlyuber Just added this so you’d be notified it’s public now.
We tried to build your code with our pipeline but it doesn’t work when I run gradlew build
gradlew build
Task :compileJava FAILED
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:15: error: package com.google.gson does not exist
import com.google.gson.Gson;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:16: error: package com.google.gson does not exist
import com.google.gson.GsonBuilder;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:17: error: package com.google.gson does not exist
import com.google.gson.JsonArray;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:18: error: package com.google.gson does not exist
import com.google.gson.JsonElement;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:19: error: package com.google.gson does not exist
import com.google.gson.JsonObject;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:20: error: package com.google.gson does not exist
import com.google.gson.JsonParser;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:22: error: package edu.wpi.cscore does not exist
import edu.wpi.cscore.CvSource;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:23: error: package edu.wpi.cscore does not exist
import edu.wpi.cscore.MjpegServer;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:24: error: package edu.wpi.cscore does not exist
import edu.wpi.cscore.UsbCamera;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:25: error: package edu.wpi.cscore does not exist
import edu.wpi.cscore.VideoSource;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:26: error: package edu.wpi.first.cameraserver does not exist
import edu.wpi.first.cameraserver.CameraServer;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:27: error: package edu.wpi.first.networktables does not exist
import edu.wpi.first.networktables.NetworkTable;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:28: error: package edu.wpi.first.networktables does not exist
import edu.wpi.first.networktables.NetworkTableEntry;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:29: error: package edu.wpi.first.networktables does not exist
import edu.wpi.first.networktables.NetworkTableInstance;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:30: error: package edu.wpi.first.vision does not exist
import edu.wpi.first.vision.VisionPipeline;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:31: error: package edu.wpi.first.vision does not exist
import edu.wpi.first.vision.VisionThread;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:33: error: package org.opencv.core does not exist
import org.opencv.core.*;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:34: error: package org.opencv.imgproc does not exist
import org.opencv.imgproc.Imgproc;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:35: error: package org.opencv.imgproc does not exist
import org.opencv.imgproc.LineSegmentDetector;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:100: error: cannot find symbol
public static boolean readCameraConfig(JsonObject config) {
symbol: class JsonObject
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:188: error: cannot find symbol
public static VideoSource startCamera(CameraConfig config) {
symbol: class VideoSource
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:79: error: cannot find symbol
public JsonObject config;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:80: error: cannot find symbol
public JsonElement streamConfig;
symbol: class JsonElement
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:209: error: cannot find symbol
public static class MyPipeline implements VisionPipeline {
symbol: class VisionPipeline
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:210: error: cannot find symbol
private Mat hsvThresholdOutput = new Mat();
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:211: error: cannot find symbol
private Mat cvBitwiseNotOutput = new Mat();
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:212: error: cannot find symbol
private Mat cvErodeOutput = new Mat();
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:213: error: cannot find symbol
private Mat maskOutput = new Mat();
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:223: error: cannot find symbol
@Override public void process(Mat source0) {
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:259: error: cannot find symbol
public Mat hsvThresholdOutput() {
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:267: error: cannot find symbol
public Mat cvBitwiseNotOutput() {
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:275: error: cannot find symbol
public Mat cvErodeOutput() {
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:283: error: cannot find symbol
public Mat maskOutput() {
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:304: error: cannot find symbol
private void hsvThreshold(Mat input, double[] hue, double[] sat, double[] val,
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:305: error: cannot find symbol
Mat out) {
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:316: error: cannot find symbol
private void cvBitwiseNot(Mat src, Mat dst) {
symbol: class Mat
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:330: error: cannot find symbol
private void cvErode(Mat src, Mat kernel, Point anchor, double iterations,
symbol: class Mat
symbol: class Mat
symbol: class Point
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:331: error: cannot find symbol
int borderType, Scalar borderValue, Mat dst) {
symbol: class Scalar
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:350: error: cannot find symbol
private void mask(Mat input, Mat mask, Mat output) {
symbol: class Mat
symbol: class Mat
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:379: error: cannot find symbol
private void findLines(Mat input, ArrayList lineList) {
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:104: error: cannot find symbol
JsonElement nameElement = config.get(“name”);
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:112: error: cannot find symbol
JsonElement pathElement = config.get(“path”);
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:134: error: cannot find symbol
JsonElement top;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:136: error: cannot find symbol
top = new JsonParser().parse(Files.newBufferedReader(Paths.get(configFile)));
symbol: class JsonParser
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:147: error: cannot find symbol
JsonObject obj = top.getAsJsonObject();
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:150: error: cannot find symbol
JsonElement teamElement = obj.get(“team”);
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:170: error: cannot find symbol
JsonElement camerasElement = obj.get(“cameras”);
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:175: error: cannot find symbol
JsonArray cameras = camerasElement.getAsJsonArray();
symbol: class JsonArray
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:176: error: cannot find symbol
for (JsonElement camera : cameras) {
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:190: error: cannot find symbol
CameraServer inst = CameraServer.getInstance();
symbol: class CameraServer
symbol: variable CameraServer
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:191: error: cannot find symbol
UsbCamera camera = new UsbCamera(config.name, config.path);
symbol: class UsbCamera
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:192: error: cannot find symbol
MjpegServer server = inst.startAutomaticCapture(camera);
symbol: class MjpegServer
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:194: error: cannot find symbol
Gson gson = new GsonBuilder().create();
symbol: class Gson
symbol: class GsonBuilder
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:197: error: package VideoSource does not exist
camera.setConnectionStrategy(VideoSource.ConnectionStrategy.kKeepOpen);
symbol: class Mat
symbol: class Mat
symbol: class Mat
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:217: error: cannot find symbol
System.loadLibrary(Core.NATIVE_LIBRARY_NAME);
symbol: variable Core
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:223: error: method does not override or implement a method from a supertype
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:225: error: cannot find symbol
Mat hsvThresholdInput = source0;
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:232: error: cannot find symbol
Mat cvBitwiseNotSrc1 = hsvThresholdOutput;
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:236: error: cannot find symbol
Mat cvErodeSrc = cvBitwiseNotOutput;
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:237: error: cannot find symbol
Mat cvErodeKernel = new Mat();
symbol: class Mat
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:238: error: cannot find symbol
Point cvErodeAnchor = new Point(-1, -1);
symbol: class Point
symbol: class Point
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:240: error: cannot find symbol
int cvErodeBordertype = Core.BORDER_CONSTANT;
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:241: error: cannot find symbol
Scalar cvErodeBordervalue = new Scalar(-1);
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:245: error: cannot find symbol
Mat maskInput = source0;
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:246: error: cannot find symbol
Mat maskMask = cvErodeOutput;
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:250: error: cannot find symbol
Mat findLinesInput = maskOutput;
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:306: error: cannot find symbol
Imgproc.cvtColor(input, out, Imgproc.COLOR_BGR2HSV);
symbol: variable Imgproc
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:307: error: cannot find symbol
Core.inRange(out, new Scalar(hue[0], sat[0], val[0]),
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:308: error: cannot find symbol
new Scalar(hue[1], sat[1], val[1]), out);
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:317: error: cannot find symbol
Core.bitwise_not(src, dst);
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:333: error: cannot find symbol
kernel = new Mat();
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:336: error: cannot find symbol
anchor = new Point(-1,-1);
symbol: class Point
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:339: error: cannot find symbol
borderValue = new Scalar(-1);
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:341: error: cannot find symbol
Imgproc.erode(src, dst, kernel, anchor, (int)iterations, borderType, borderValue);
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:351: error: cannot find symbol
mask.convertTo(mask, CvType.CV_8UC1);
symbol: variable CvType
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:352: error: cannot find symbol
Core.bitwise_xor(output, output, output);
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:380: error: cannot find symbol
final LineSegmentDetector lsd = Imgproc.createLineSegmentDetector();
symbol: class LineSegmentDetector
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:381: error: cannot find symbol
final Mat lines = new Mat();
symbol: class Mat
symbol: class Mat
C:\Users\Student\Documents\rpivision\src\main\java\Main.java:386: error: cannot find symbol
final Mat tmp = new Mat();
symbol: class Mat
symbol: class Mat
100 errors
FAILURE: Build failed with an exception.
Sorry for the wall of text but I’m very confused as to why this is all failing. We’ve been trying without any results to make headway but we can’t. Any advice?
#10
Are you connected to the Internet? It should pull in the dependencies on it’s own…
#12
I updated the build file a bit and it fixed most of the issues except for this:
bad class file: C:\Users\Student\Documents\rpivision\libs\cscore.jar(edu/wpi/cscore/MjpegServer.class)
class file has wrong version 55.0, should be 52.0
Please remove or make sure it appears in the correct subdirectory of the classpath.
#13
Odd, I can build it just fine.
All I literally did was change the process method in the example build, so you could try to download the current java example from your PI, and just try to insert our process method to see if you get different results.
Maybe we have differing versions of the libraries somehow.
#14
Seems like you might be using the wrong JDK. WPILIB is built for OpenJDK 11, however, from the looks of it you’re using JDK 1.8.
Make sure your JAVA_HOME, or Environment SDK is set to C:\Users\Public\frc2019\jdk
#16
@NewtonCrosby @Kinzerfest Thank you SO MUCH for your help! We’d be dead in the water without y’all :slight_smile:
