**TL/DR:**Old guy tells a story then asks “How much change do you have to make to a robot before you need to get it reinspected?”
Hey CD,
I was helping a team get their climber working at NE RIDE (awesome fun competition – really enjoyed being involved).
Anyway, after the draft but before the playoffs, the Bat Signal went up in the pits for a “64:1 gearbox” Really? a 64:1 gearbox - that’s it? Seems like there had to be something more specific they needed than just any 64:1 gearbox some team happened to pack from the gearbox boneyard*. I had to go check that out.
Turns out the team had a CIM + Banebot 64:1 gearbox (BB220???) and a roughly 4" winch drum. Solid enough solution I would think. Should lift 150lbs at about 1 ft/sec drawing about 30A. Not bad. But it was broken, they didn’t have a spare and they needed a work around.
Team 88 just happened to have a VersaPlanetary stash, an extra 775Pro, and a VersaFrame Gusset for a VersaPlanetary** laying around in our pit***.
So I set to work to build up a 250:1 VP with a 775Pro input and an output with their required 1/2 round shaft with keyway****. Should give them very similar performance in terms of climb rate and currents.
We were almost done when the robot had to be carted off to the inspection station to get reweighed and reinspected. I don’t think this was the “every robot that competes in the playoffs” gig. I think this was because they thought that the change required it.
It wasn’t the ONLY reason they didn’t get their climber working before they were eliminated but it definitely was a big part of it.
I am not going to advocate breaking rules or anything but it didn’t seem to me that this was a very significant change. They replaced one legal motor/gearbox for another legal motor/gearbox that essentially duplicated the one they were replacing. If anything the weight dropped by a few pounds.
I would have probably said they’d be okay to just hop in the robot queue and compete.
Would I have been wrong?
What does the CD community think?
Do tell.
Dr. Joe J.
*Any team with more than 4 seasons behind them has such a boneyard: No real use for this gearbox anymore, but it’s too good to toss. What are you going to do with it? Put it in that pile there.
**I swear, I am not on the payroll of the Vex folks. I just like many of their products. I’m just as happy to say good things about BB or AM or WCP or JoeBlow’s FIRST Gadgets as long as they make useful stuff for FIRST teams to more easily realize their robotic aspirations.
***in case we ever get a hankering for some tasty cheesecake. You know what I’m talking about…
****Really folks, use hex shaft if you are transferring torque with a shaft in FIRST applications – Trust me on this. Yes, you can make keyways and keys work but hex is your friend. You’ve got a lot to worry about on a FIRST team. Transferring torque via shafts shouldn’t be one of them. Use hex shaft whenever you can. And buy the AM broach. Worth it.
