What type of Fairlane Wheel do you use?
Our team was kinda blindsided. At our workshop we were full field shooters with extra range, but when we got to our first competition this weekend, the airholes in the ball threw us off completely. We were able to add some compression to help but it still wasn’t enough to get the performance we had before. We were just using a set of acrylic wheens on our shooter… but noticed a lot of teams using Fairlane wheels… in particular big fairlane rollers.
Teams that are using these wheels… have you found a particular one better than others?
What makes these fairlane wheels better? is it the grip? I read they expand slightly at speed… is it that? I just want to pick people’s brains
Im very curious as to what these wheels were. Acryllic shooter wheels sound lowkey cursed.
Most Fairline wheels are either the 4in or 6in (probably 6in), and can be found on WCP/McMaster. Will probably need to fit your own hubs though.
Your wheel choice is not going to make broken balls more consistent. The issue is that damaged balls compress quicker, leading to less KE transferred into the ball, which would happen with essentially any type of launcher wheel.
agreed but it seems like better grip on the ball with those fairlane rollers. Also if they expand upon rotating I would think that would help.
haha I guess they were low key cursed… I think we would get better grip on the balls with the fairlane wheels
We use 4 inch fairlanes (I think neoprene but I might be wrong?) because they were an easy solution to give us enough rotational inertia (which might be a problem if using hollow acrylic wheels) and work in the rpm ranges we wanted (up to around 8k). We used the space coast products hubs which were good. They are definitely sticky when you first get them but we found by the end of Plano the stickiness was mostly gone. We are going to compare with our spares and see if that caused some of our shooter problems. Overall, we were pleased with them. 9/10
Where did you guys buy them… Seem to be out of stock :frowning:
McMaster
https://scprobotics.com/catalog?olsPage=products%2Ffairline-hub
