I haven’t seen much discussion on when to actually use the vault and it seems like it would be a good discussion. It would be a shame to see an alliance use Force 1 while already in control of their switch.
A quick rundown of the vault details:
- With 3 human players, you’ll likely have 1 assigned to the vault with the other 2 at the portals.
- Once a cube is in the vault it cannot be removed
- A powerup can only be used once
- Only one timed powerup can be in use at a time
- If another powerup is used when one is already active it will be in a queue to start immediately after the previous one
- the Previous point is for the opponent only. If Red uses a powerup then tries to activate another before 10s it will be IGNORED (Thanks Harkema)
- Levitate can be used at any point and will still count at the end of the match
- A cube does not have to be in the vault right away per 4.2 number 3 (Thanks McLeod for seeing that)
Powerups:
- **Levitate **
- grants climb to one robot - 45 total points max (15 if you already have 3 climbers) - Force 1
- grants ownership of your switch for 10s - 15 total points max (keep in mind you may already have ownership or match time may run out) - Force 2
- grants ownership of the scale for 10s - 30 total points max (10+10+(10 denied to opponent)) (Thanks Rangel) - **Force 3 **
- grants ownership of both for 10s - 45 total points max (15+10+10+(10 denied to opponent)) - **Boost 1 **
- double points for 10s while you own your switch - 25 points max - Boost 2
- double points for 10s while you own the scale - 30 points max - **Boost 3 **
- double points for 10s while you own both - 55 points max
Unless you are 100% sure you have 3 climbers, I would say get Levitate, but make that a second/third vault target.
Also, if you used a LVL 1/2 powerup already, ignore filling it till the other powerups are used/filled
Force is actually really nice early on as the match starts and you get a feel for how things are playing out. They have a switch killer? Force 1 gives you a buffer to figure a counter strategy. Or say your scale bot is getting hung up on something (happens a lot) Force 2 buys them time to reorient.
Boost will be big if you can own the switch and scale at the same time. I think some teams will try to get Boost 3 then once owned, ignore the cubes to have 3 bots push others away for 10 seconds. Here pushing will gain you the same points as cube placement and may be easier.
Has anyone thought about how/when they want to use their powerups?
I’m very interested to hear.
