Where Are "Chassis & Drive Train Instructions"
Page 5 of ‘FIRST Guidelines, Tips, & Good Practices’ has the following paragraph:
found at http://www2.usfirst.org/2006comp/other/FIRST_Guidelines,Tips,&_Good_Practices.pdf
G.3.2 THE CHASSIS - NEW IDEAS
The Chassis & Drive Train Instructions provides step by step instructions to assemble the Chassis kit and for mounting the Drive Train. There are several ways these parts could be configured to form a chassis. One example is shown above. Additional concepts for assembling frames are found in Drive Train Improvements,“The next step…” The design decision will be defined by the team’s game strategy and the functions the robot needs to perform.
The text ‘Chassis & Drive Train Instructions’ and 'DriveTrain Improvements, “The next step…” are in blue, which typically means a link in pdf files. However, they are not linked to another document. DO THEY EXIST, AND IF SO WHERE ARE THEY?
Thank you.
These documents can be found on this page:
http://www.ifirobotics.com/kitbot.shtml
Direct Links to the PDFs:
http://www.ifirobotics.com/docs/Chassis%20&%20Drivetrain%20Assembly%20Instructions.pdf
http://www.ifirobotics.com/docs/2006-first-transmission-manual-rev-d.pdf
http://www.ifirobotics.com/docs/Drivetrain%20Improvements.pdf
