I was on the VEX website recently and I found that Spike relay modules weren’t listed anywhere. What has happened? Is IFI discontinuing them?
I figured that this would have been noticed and mentioned on these forums, but a search turned up nothing. Does anybody (perhaps someone involved with VEX product development) know what is happening?
I have some pictures of the new relay, and a comparison shot of the two relays. I’ll post those as soon as a get to a desktop, but for right now here’s a link to a forum post about the relays. Just remember that this is all from beta and may have changed.
Did these fail the beta testing and get delayed a year?
Since those appear custom made for FRC, why won’t the vendor at least put WAGO terminals on them? Those are much more secure for unterminated wires. (Or, if they’re interested in wires with connectors, maybe Anderson PowerPoles or screw terminals for ring connectors?)
Nice of them to incorporate several outputs and parallel relays into one module.
AFAIK, they were set as a 2013 release at the time of the beta… My only guess to why would be related to production, as you would have to test it TWO beta seasons in advance since it could presumably take one year of advanced notice to have enough final-revision product made for the KOPs and the like. It’s not like the kinect which was a pre-existing product that was already in production.
Those two 20 amp fuses are misleading - if you run it from a 20 amp breaker on the PD board. For us, the 40 amp slots are usually pretty close to full or filled, so running it through a 40 amp breaker may or may not be possible for your team, depending on design.
You can already run two different objects/lights/etc off a single spike now. You just have to run your ground back to the input ground for the spike, and power a different item off each prong.
So far, this product seems to be an answer to a question that hasn’t been asked.
At the Beta Test team get-together in St. Louis, we learned that there was a list of things to address for a production version of the David relay module. The connection method was one of them.
The Spike is right underneath the Victor. It is out of stock because FIRST is the only customer (and FIRST teams) so they will be back in stock in time for the FRC season.
Nope - it was known going into the Beta test that these items would not be used in the 2012 season. FIRST was putting them out there for testing regardless so they could get feedback and improve them before they (if they) are made available and legal.
We tested the new relay this past year and loved the form factor and the fact that you have a ground on the output side (in addition to fwd/rev) to give you more options for wiring your loads. The SPIKEs have always been pretty nice but they are a bit bulky and the outer shell always seems to split top from bottom for us (hot glue is pretty much a given here). If the new ones are made legal it will be nice to have a more compact option (this year our bot was so small we found ourselves having to make artificial surfaces to mount electrical components!); price, reliability (yet to be seen for the new module!), and the need for compact form factor will lead us to which we’ll use in the future if both become legal. Both seem to be good options.
