If I try to locate a charging tip that works with the 2GO netbook is says it can’t find one. Does the tip you use have a number on it? ANy other way to ID it?
Does the Radio-Shack one come with a compatible tip?
Sorry, I meant DC-DC converter. People keep referring to it as the “battery” :rolleyes: now they have got me doing it. I’m pretty sure we use it with an Anderson connector as instead of cigarette adapter. I really didnt work on it or even see the finished product (just a cable attached to the cart), I just suggested it based on a Eugene Brooks post.
[EDIT]
I think we just bought it from Radio Shack. It was purchased and built quickly as we were motivated by loss of comms due to low Classmate battery in Chesapeake SF1-4 that lead to our elimination. You probably could compare power adapter tips in the store.
Someone tried to bring them back the blue box DS at Philly this year. It worked in the shop atleast. Luckily, we got them a Classmate and updated code.
[/EDIT]
I just got the (only) iGO travel charger at my local (45 miles away) Radio Shack.
So… in case anyone wants to buy the cheaper unit online from www.iGO.com … the card that comes with the unit indicates that the “206” tip is the one for the CTL 2GO Netbook. I’ll know later if it really is the right one
I’m glad you got one. I forgot about your locale, 45 mi to Radio Shack is crazy :ahh:. I drive past at least 3 Radio Shacks on the 10 mi drive to our shop.
If anyone has a “dead” classmate, I’d like to buy it from you for the screen. Ours decided to take a dive off the table and the screen is now only half viewable (other half blank). The PC works OK, and I hate to spend $500 to replace it. Oh, and the power charger was so disgusted with the PC diving, it ran away and cannot be located (need it too).
We thought we had a dead Classmate. The computer quit recognizing the battery. Anytime we’d boot the classmate, it would try to boot Windows and then shut down (thinking its battery was dead) or it wouldn’t boot at all. When we swapped the battery into a different classmate everything worked just fine. No problems with the battery…
Before we went down the road of getting a replacement (which did not look like a trivial process) we called GoToPC’s tech support.
Apparently they are aware of this issue and they have a fix. I was not the one that called, so I cannot say what the fix is. The person that did call said it was a hardware reset and the Classmate has been working just fine since. Give them a call… It might not be as bad as it seems…
