Where is image20.jpeg?
We’ve looked everywhere for at least a couple (sad) hours and still can’t find it. It’s referred to in the wpilib sample project for vision/color tracking (2015 Vision Color Sample). Has anyone been able to find it?
Edit: If someone could even just throw it on imgur, that’d work.
Edit 2: Never mind! We found it in the wpilib git, but never managed to find it anywhere else, so problem solved!
Did you try: C:\Program Files (x86)\National Instruments\LabVIEW 2014\examples\FRC\roboRIO\Vision\2015 Vision Example\Sample Images
If you are looking at the LabVIEW example, the default path is something like:
“Sample Images\Some Name”
Remove the second part so the path is just “Sample Images” and run it.
We are doing it with eclipse, can you show us where to download the LabView files?
Well in that case:
Seems if you just install LabView by itself you get all the pictures.
Here’s an imgur album of all of the sample pictures: https://imgur.com/a/JKPnu They’re in order, so #20 is the 20th picture (the one with a single tote and can)
EDIT: Or you can check the link above. That works too.
