who gets the points?
if you are on the opponents platform at the end of the match, does the opponent get the points for having a robot on the platform?
See Rule <G09>
<G09> ROBOT on ALLIANCE PLATFORM - ROBOTs score points if they are entirely on an ALLIANCE PLATFORM at the end of the match. ALLIANCEs receive points for ROBOTs belonging to either ALLIANCE that are on the ALLIANCE PLATFORM closest to the ALLIANCE’s DRIVER station. If any part of the ROBOT is touching the carpet, the ROBOT is not considered on the platform. If a ROBOT is entirely on an ALLIANCE PLATFORM and is touching another ROBOT that is not entirely on the ALLIANCE PLATFORM, it still is considered on the platform. One ROBOT on a platform or ramp is worth 5 points, two ROBOTs are worth 10 points, 3 or more ROBOTs are worth 25 points.
A red robot on the blue alliance platform at the end of the match will earn points for the blue alliance. So the message is: make sure you are at your own end of the field at the end of the match!
-dave
Yes, or make sure you steal other robots for your own ramp! :stuck_out_tongue:
Or you may choose to do this because say the score is 15 to 5, do some quick math and it may benifit you to go to their side for more QPs, but you must be very careful when doing this as you are kinda playing with fire and if there is a penalty you dident see… you may loose the match for yourself.
just a random question: what if your able to get an opposing alliance robot on your ramp then you manage to get yourself off the floor, making it so you have FOUR robots on the ramp, would it still be 25 points or would it be more?
psycho7,
if you read the end of rule <G09>, it states “three OR MORE robots”…on the platform…“are worth 25 points”…
So, no point in dragging the enemy with you to your victory dance on the platform.
But, I think that fashion points should be awarded for getting the tallest robot into the middle position at the end of the match…
and even more if you can stack the 3 or more robots in the upwards direction. freestanding,.
I have a strange feeling that robot stacking would be against the rules.
Do you have a rule to back up that feeling?
Wetzel
I did, but I lost it.
I think the below rule covers his feeling.
Also there is the rule about having your robot’s faces at no more then a 10 degree tilt, which would be almost impossible for a robot to climb.
