Why are Phoenix6 units in turns?
When I try to get data from a sensor with the Phoenix6 API, it returns values as a units::turn, as opposed to degrees or sensor ticks. I guess all I want to know is why use rotations as the default as opposed to encoder ticks or degrees?
As for why turns instead of ticks, physical units are easier to work with and convert. Turns vs degrees is an aesthetic choice, and units::turn_t will autoconvert to your preferred unit type on assignment.
Turns is the “natural” unit of rotation for most applications.
Mathematically, an argument can be made for radians - but radians are often inconvenient in physical application. Degrees are highly-familiar but weird and arbitrary.
As @calcmogul noted, the C++ units library will implicitly convert to whatever units you want.
As both Tyler and Oblarg have pointed out, turns is a more canonical unit type than encoder ticks, as they represent an angular position independent of the hardware. Other advantages:
  • Rotations are really easy to convert to other units – Multiply by 360 to get degrees, and multiply by 2pi to get radians. C++ teams get this for free with the units library.
    • Much of WPILib (particularly simulation) also operates in radians per second, rotations per second, or revolutions per minute, which all convert well to rotations.
  • Rotations are easy to reason about – What angle is 1.257 radians? It’s a lot easier to visualize 0.2 rotations.
  • Rotations are often mathematically nicer to work with than degrees – A lot of math operates in radians and radii, or it operates in rotations and circumferences. Degrees almost always need to be converted to radians or rotations somewhere down the line.
  • This wasn’t a deciding factor, but your PID/FF gains with degrees would also be very small – The Kraken X60 has a top speed of around 100 rotations/second, which is a kV of ~0.12. The degrees equivalent would be 36,000 degrees/second, which is a kV of ~0.00033333…
Rotations are honestly the best balance between human understandable units and a mathematically useful unit.
Want to do math with it? Multiply by Tau
Want to think of it visually? Half-turns, quarter turns, eight-turns are also easy to visualize
