The problem is that it never actually shows up. I use the connector indicator icon and it shows that it is indeed connected but my options never show up. Is there something else I should be doing? I have tried just doing
wpilib.SmartDashboard.putNumber("Something", 3)
and that doesn’t show either when connected. Any ideas or suggestions are welcome! Thanks!
We are a java team. Here is our code that does multiple autos
public void robotInit() {
updateDashboard();
autoChooser = new SendableChooser();
autoChooser.addDefault("Default Autonomous does nothing!", new Default());
// Default Autonomous does nothing
autoChooser.addObject("Cross the Low Bar Don't Run This it doesn't work", new LowBar());
autoChooser.addObject("Cross Rough Patch/Stone Wall", new Main());
autoChooser.addObject("Cross the Low Bar, Experimental!", new LowBarEx());
//autoChooser.addObject("If Jonathan lied to us and we can cross twice", new RoughPatch());
CameraServer server = CameraServer.getInstance();
server.setQuality(50);
SmartDashboard.putData("Autonomous", autoChooser);
Try opening a new dashboard/recompiling/running teleop for a bit
I can now found that I can do the normal “wpilib.SmartDashboard.putNumber” stuff, but the sendable chooser still refuses to work. I tried starting new dashboard, but the variables keep coming back from our old robot. I have even deleted the save file and somehow it stills finds it way back onto the dashboard.
robotpy has an autonomous selector class that you can point at a directory of .py files and it’ll setup a chooser that should work with SmartDashboard.
