Why isn't this working?
#include "WPILib.h"
#include "Utilities.h"
#include "math.h"
// #include "Vision/AxisCamera.h"
const int servo_pwm = 4;
const int switch_one_port = 12;
int state;
UINT32 last_switch_state;
float desired_angle;
float last_recorded_angle;
class RobotDemo : public SimpleRobot
	Servo mainservo;
	DigitalInput servoswitch;
	Timer servoTimeout;
	public:
		RobotDemo(void):
		        mainservo(4),
			servoswitch(switch_one_port),
			servoTimeout()
				GetWatchdog().SetExpiration(0.1);
				// AxisCamera & camera = AxisCamera::GetInstance();
		void OperatorControl(void)
			GetWatchdog().SetEnabled(true);
			state = 0;
			last_switch_state = servoswitch.Get();
			while (IsOperatorControl())
				GetWatchdog().Feed();
				switch (state)
					case 0: // wait for servo action
						if (servoswitch.Get() != last_switch_state)
							state++;
						cout << "Waiting for switch action..." << endl;
					break;
					case 1: // start moving the servo
						cout << "Servo has started moving." << endl;
						if (servoswitch.Get() == 0)
							mainservo.Set(0.0);
							desired_angle = 0.0;
						else
							mainservo.Set(1.0);
							desired_angle = 1.0;
						servoTimeout.Reset();
						servoTimeout.Start();
						recordAngle();
						state++;
					break;
					case 2: // servo is moving to desired angle
						if (servoTimeout.HasPeriodPassed(0.5))
							if (mainservo.Get() != desired_angle)
								if (fabs (mainservo.Get() - last_recorded_angle) < 0.1)
									state++; // the servo is obstructed by an object
							else
								state++; // Servo has moved to the desired angle.
							recordAngle();
							cout << "Current angle: " << last_recorded_angle << endl;
					break;
					case 3:
						cout << "State is 3." << endl;
						mainservo.Set(last_recorded_angle);
					        state = 0;
					break;
				// cout << mainservo.GetAngle() << endl;
		void recordAngle()
			last_recorded_angle = mainservo.Get();
START_ROBOT_CLASS(RobotDemo);
What I am trying to accomplish is the following:
  • I have a servo (which works properly, and is wired properly).
  • I want to flick a switch which is declared as a DigitalInput, constructed as DigitalInput 12.
  • When I flick this switch I want the servo to move to either full left or full right (depending on its current position. I want it to move opposite of its current position).
  • I want to account for objects obstructing the path of this servo. If the servo hasn’t reached the position I told it to go to, and it hasn’t moved more than 18 degrees in 500 milliseconds, then we can assume there is an object obstructing it, so I want to stop the servo from moving.
I have multiple problems with this program. One problem is that in case 0, state++ never gets executed, and I can’t figure out why. Assume that cout is working properly (because I have the cRIO properly connected to another laptop via serial cable). However, I am not sure whether cout messes with anything.
Also, the code just straight up doesn’t work. Before, I had managed to jump into case 1 (I kinda had to force it) and even so, my code wasn’t working. I would be most grateful if someone could give me a few pointers on what I’m doing wrong, or even if I am attacking this from the right angle.
Can you put more debug in there? Debug is your friend.
Also, does case 0 run once or never? From a quick examination of the code it looks like
“last_switch_state = servoswitch.Get();”
right before your while loop would result in
“(servoswitch.Get() != last_switch_state)”
returning true always, especially if no or very little time elapses between the two statements.
