okay when the camera is in search mode it usually tilts up goes through one left right cycle, goes to a middle point scans left and right, then pans down and scans left and right… now recently it just tilts up while facing towards the right, then tilts back down to middle and scans left/right … effectively it never tilts except when at the far far right and even then only up not down…!
what can explain this wierd behavior? serial port stuff perhaps? i can’t figure it out…
we had the same problem, it ended up being a glitch in the search routine, check and make sure you didn’t mix up any = and == we ended up just rewriting ours.
We had a similar problem, except we had the servos on the mount attached wrong so they weren’t center. AKA the camera wasn’t mounted properly for the search values. Try taking off the camera from the servos, assuming your using the defualt value, and recentering it.
Just as a possibility, when ours spazzed out like that for no apparent reason, I found that the lens had been screwed all the way down by the vibration! :ahh:
When the camera is way out of focus like that, very wierd things start to happen
Put some tape around that lens ;)! Our bot vibrated so much, we had to locktite all the screws around the camera, cuz they kept falling out, but it still stayed in focus!
