Will not build due to break in vision processing
I’m from team 4375 … trying to build code but I’m getting an error in vision processing… didn’t touch that Vi … in the past camera worked automatically… any ideas what is going on?
Can you open one of these VI to see exactly why it is not executable?
It says it is not properly licensed
Well, you have your problem right there.
Try this and see if the problem is solved.
Follow the link provided to activate and that should solve this specific problem.
In the future, notice there are errors with a red X and others without. Those without are breaking because of a dependency being broken. You’ll want to focus on the red X errors. They’re the dependencies breaking the other VIs. Once you fix those, the rest will be fixed as well. Scrolling through the rest will just frustrate you.
